Question about Radio Communications
SOURCE: pairing a nexus drivesmart
To put the Drivespeech into pairing mode - with power OFF, press the power on button until the Drivespeech powers on and CONTINUE to hold the button until it announces it is in pairing mode and the LED flashes alternate Red/Blue.
Select 'Discover' on your phones Bluetooth menu and enter the code when requested (usually 0000 or 1234)
HTH
Posted on Mar 23, 2009
SOURCE: plantronics 2XX pair code
The pairing pin should be 0000, most bluetooth device's use all 0's.
Hope this help's.
Posted on Apr 17, 2009
SOURCE: Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Posted on Apr 22, 2009
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
SOURCE: Problem Pairing Blackberry 8700 w/ BlueAnt Z9 Bluetooth Headset
This problem has been solved by turning on the blue ant system then holding down the vol - and vol + buttons simultaneously for 5 secs.
Posted on Oct 27, 2009
