Question about Braun Health & Beauty
Just want manual Braun 7505 book not online - Braun Health & Beauty
Posted by John k Ferguson on
5 Related Answers
Biggle Azuaje
SOURCE: switch is stuck in on position braun 7505
You only need an small screwdriver, pull out the blue button and the metallic part, Ready!. Only one thing, you have to forgett about the aesthetics of the shaver, but it's work perfectly, Thanks a lot!
Posted on Nov 09, 2009
brector3
shaveroutlet.com
  • 1645 Answers
SOURCE: Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Posted on Jan 16, 2010
brector3
shaveroutlet.com
  • 1645 Answers
SOURCE: Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jul 15, 2010
brector3
shaveroutlet.com
  • 1645 Answers
SOURCE: I am interested in finding
charge time is 1 hour for this model
Posted on Sep 30, 2010
Anonymous
  • 214 Answers
SOURCE: Can I use my Braun
you need a converter , check out this site for info
http://www.enjoy-europe.com/hte/chap11/electric.htm
Posted on Jan 16, 2011
Looking for manual for radio/cd player 7505
Please let us know if the following free manual is applicable or not by using the Comment menu. AVC7505 may be the same as 7505.
http://www.audio2000s.com/products/player/AVC7505MANUAL_2011_08_17.pdf
3helpful
I need a new battery for this razor. I know its replaceable, but where dose it go and how do you get the cover off?
You will find the correct battery type for model 7505 at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
You will need two batteries. Scroll down the item page for videos showing disassembly and installation tips
9helpful
2answers
2helpful
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
1helpful
Shaver not charging.
The batteries should not really get warm. You may not have a good solder connection
Assuming that the batteries are in correctly with good solder joints, the problem is likely the motor. With the shaver fully assembled, remove just the foil and cutter and then turn the unit on. Use your finger to push the piece of plastic that the cutter fits into back and forth. If it starts and moves slowly or if it stutters, the brushes in the moto are probably bad. Because the motor is a sealer unit, the motor will need replaced. If you require this part, you will find it at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
2answers
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
