Question about HP Televison & Video
HP Touchsmart 310-1033. My computer works, however; I can't see the screen too clearly. It flashes or blinks as if it's going out. I did a diagnostics and then took it to the shop to do their diagnostics and nothing. It's not a hardware issue. The repair shop wants to charge me $99 just to open up the computer to see. I'm looking for a less affordable option. A DIY option, if possible. Does anyone know what can be the issue? As I mentioned before, computer works, I just can't see the screen. It looks like how a TV looks with white snow or white noise or fuzzy.
Posted by Tina R-H on
  • HP Master
  • 18,438 Answers
The first thing to do is go into the device manager and delete the drivers for the display and let windows reinstall them. It may be a bad or out of date driver. So when you restart the computer it will put the driver back. Since you did not post the operating system, there is not a lot more I can tell you. If this does not help, you can try an external monitor to see if the problem is present there. If it is then it may be a display chipset issue.
Posted on Jul 14, 2018
  • 1 more comment
  • Tina R-H
    Tina R-H Jul 14, 2018
    I'm sure it would be helpful but I can't see anything. I would have to rely on memory to know where the drivers are or to access anything like a folder or document.
  • Tina R-H
    Windows 10
  • Brad Brown Jul 15, 2018
    Click the search icon and type DEVMGMT.MSC when it shows up in the list above click on it then look at the list and select the > sign next to display adapters and the current one shows up, Right click on it and select uninstall device and then continue with the process. Then restart the computer
4 Related Answers
Anonymous
  • 10 Answers
SOURCE: White speckly 'snow' on screen
y sustain board needs adjusting or replacing
Posted on Jan 29, 2008
Anonymous
  • 400 Answers
SOURCE: Solid white screen on my laptop
sounds like the on-board video card is dying/ or the screen is dying too
Posted on Jul 10, 2009
Anonymous
  • 15 Answers
SOURCE: tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Posted on Sep 12, 2009
Anonymous
  • 62 Answers
SOURCE: HP TouchSmart IQ770 PC Desktop replace screen
Hi ,
I have pasted the url so kindly copy paste it in the address bar and you will find the moving pictures .All u need to do is just roll the mouse over the picture and u will find something interesting ....It gives u the steps to replace the screen...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01060928&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3351220
hope this will help u .....all the best...
Posted on Mar 19, 2010
Hp 310 touchsmart has black screen at startup
310 dash what? 310-1000? it really and all-in-one PC.
what is the full model name and number.
no text? screen never ever shows any thing?
is the fan running inside, and blowing air.? it must.
the steps are here at hp.com
https://support.hp.com/us-en/product/hp-touchsmart-310-1000-desktop-pc-series/4273627/manuals
PC boot in serial progression.
power on
fan blows.
BIOS POST's with errors if found. (3 ways) beep ,text or flashing keyboard led codes.
bios text mesages, logos
windows boots.
windows login, screen
last desktop and (startup files load)
where do you land here.?
see no power? there?
Aug 10, 2018 | HP Computers & Internet
The screen touch does not work
try this if no go please post back thanks.http://h30434.www3.hp.com/t5/TouchSmart-PC/TouchScreen-not-working-in-TouchSmart/m-p/1850987#M16027
Jan 04, 2014 | HP TouchSmart IQ770 PC Desktop
Can't use touch screen on hp smart touch
If it is TouchSmart you have an issue with, go to the control panel and select touchscreen configuration. Make sure your global touchscreen settings are set to enabled. Click save and then close.
If this is not the issue it is possible there are hardware damages to the touch screen. Has it been dropped at all?
Jan 07, 2013 | HP Touchsmart Iq500 Driver Recovery Disc...
HP TOUCHSMART 10526 GETING --NOT ENOUGH SPACE IN RUNTIME AREA -- SMBIOS DATA WILL NOT BE AVAILABLE this happened be 4 any bios update was done --RUNNING VISTA 32 HOME PREMIUM -- GET BLUE SCREEN SAYING NOT...
By the sound of it you have a BIOS problem. This can happen with a bad flash of the bios HP automatically updates the system if you have not shut off that feature. You may have recieved a bad update. It may also be youre power supply. Check to see if your power supply has the full voltage if you have a Voltmeter. Try reflashing the Bios if you can and make sure to check the "clear nv ram" feature if available during the flash process.
Hope this helps... Dale
Apr 20, 2011 | HP TouchSmart tx2z
Touchsmart tx2z Screen Flickers and Freezes
it seems the touch part is off center because when i touch the screen it reacts one finger over
Jul 09, 2010 | HP TouchSmart tx2z
The lightning bolt on my hp touchsmart tx2 flashes
that means your laptop has no power so your battery is dead which would explain why it shut down on you, and that means its not charging so it would either be the adapter or the port on your laptop
Feb 27, 2010 | HP TouchSmart tx2z
My ambinent light is blinking on my hp touchsmart. the button on the left on the computer turns the light on and off and has three settings. currently, it blinks through all three settings then turns off...
sounds like either the switch controlling the light is not working or the or the abient light is burnt out causing a short. If under warranty Have this check out by an Hp Tech.
Apr 01, 2009 | HP TouchSmart IQ770 PC Desktop
Televison & Video Logo
85 people viewed this question
Top HP Televison & Video Experts
Edward Easley
Edward Easley
Bernie Scott
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
