Vacuums Logo
Question about Kenmore Vacuums
I have a Kenmore Progressive canister model vacuum cleaner #116.21614015. Without warning, the hose will not release Pet Power Mate tool. Release button seems to be stuck. Help, please. Thank you.
Posted by Sheila Gierisch on
5 Related Answers
Anonymous
  • 1673 Answers
SOURCE: Kenmore canister model 116.25512 won't start
Sounds like you have a switch problem. Some of the Sears models also have a relay in them, which could be bad. The complete model isn't stated so couldn't look it up. But you can go to Sears.com, click on parts, enter your complete model number and a parts list with diagram of parts will come up.
Posted on Feb 14, 2008
EMS
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
Anonymous
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
Anonymous
  • 84 Answers
SOURCE: Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Posted on Nov 10, 2009
Anonymous
  • 231 Answers
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Posted on Jan 04, 2010
Connectors on Kenmore Power Mate
to take the hose off, you just depress the clip at the end but there is no easy way to remove the connectors off of the ends, it just must get cut out and the new one pushed in and sealed
Let me know if you need any further help
I own a Kenmore vacuum cleaner model # 116. 56550990C. I have lost the instructions to replace the belt in the Power Mate. The Power Mate beater just stopped working and I need instructions on how to...
If unit beater has stopped working it is either the motor, the power connection to beater or the belt that powers the roller. Which is it?
See if you can download the manual from the mfg or google for it.
2answers
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
3helpful
How do i open the roller area to my kenmore canister vacuum
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
1helpful
Remove connectors off hose
Are you talking about the hose cuffs? If so, put the cuff in a vise and squeeze it until you see the locking tabs and using flat blades, pry the hose out from the cuff.
3helpful
2answers
Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
Open Questions:
Top Kenmore Vacuums Experts
Marvin
Marvin
David Shaub
Mike
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
