SOURCE: Samsung 55" TV does not turn on
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
SOURCE: samsung ln40a530 blinking red light, no video
Blinking lights are usually an error code. Do you have a manual that will decode the number of blinks? Its not always the power supply.
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
SOURCE: will a power supply for a 50" plasma TV work with a 42" plasma TV?
sir it will work with your TV..
Were would I find that open internal fuse . Like I said was told it probably power supply board no so replaced it still no change. Told power cord replaced with another cord still no change
