Question about Vulcan Heating & Cooling
SOURCE: I have a vulcan quasar
Perhaps the fan motor is bad. If not, you have an electrical problem.
Posted on Jul 24, 2008
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
SOURCE: limit switch open furnace wont heat
If the limit switch is open try to jump the wires out... this should turn the heat back on. and if it does replace limit... if it dont let me know and we'll try again
Posted on Apr 06, 2010
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
Apr 05, 2015 | Vulcan Heating & Cooling
Mar 10, 2015 | Vulcan Heating & Cooling
Oct 25, 2012 | Intertherm 56000 Btu Gas Furnace
Sep 01, 2011 | Heating & Cooling
Jan 09, 2011 | Dayton Gas Furnace Heater
Dec 06, 2010 | Heating & Cooling
Oct 05, 2009 | Heating & Cooling
Jun 13, 2009 | Heating & Cooling
Jan 26, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
48 people viewed this question
