Question about Samson Audio Players & Recorders
Samson servo 600 amp ch 1 sound cracks
Samson amplifier model servo 600, amp ch 1 sound cracks and ahs very low volume i checked the transistors and its all or is it the capacitors that is causing the problem ?
2 Related Answers
Anonymous
SOURCE: Samson Servo 170 - 1 dodgy channel
http://www.soundonsound.com/forum/showflat.php?Cat=&Number=403253&Main=351397
Posted on Dec 17, 2007
Anonymous
  • 14 Answers
SOURCE: Samson Servo 170 Amplifier
check see if youy have some coving the vent or the speak connect right
Posted on Dec 22, 2007
Blown Samson servo 170
The amplifier have problem with the out put drive section. Repairing of such an amplifier should be done by a skilled person. there should be need of repacing so many components if the out put driver transistor is short. If you make any mistake the components you change will also go in to fire.
Ajin
Mar 31, 2012 | Samson Servo 170 Amplifier
Hi, i have been suggested first a Samson servo 600, then a sx1200 is there a difference between the 2? is one better than the other?
the servo series is geared more towards studio applications and/or installs, while the sx series are geared for live pa applications. the servo 600 is 300 watts per channel @ 4 ohm, and the sx1200 is 450 watts per channel at 4 ohms. the sx amp can also be bridged over to mono mode, where it puts out, i think, 1100 watts mono.
the only variable i havent been able to cover is sound quality, and im not seeing those listings in the specs on the samson website
Jan 12, 2011 | Samson SX1200 Amplifier
Samson servo 300 right channel low output power protection on.Left channel ok.
Hi...
This amp will need to be serviced
Check on the web for someone who does audio/stereo repair in your area
Jan 22, 2010 | Samson Servo 300 2-Channel Amplifier
Dec 05, 2007 | Samson Servo 170 Amplifier
Dec 02, 2007 | Samson Servo 170 Amplifier
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
