Question about Samsung Car Audio & Video
Trying to connect my Samsung HW-F450 sound bar to UR5U-8780L remote
Trying to connect it to the Aux button but won't work.
Posted by Leo Jolly on
5 Related Answers
bshldn
Loretta Northcutt
  • 736 Answers
SOURCE: I have a Samsung hw c-451 sound bar.I have it
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
Posted on Jan 27, 2011
gopakumarg43
  • 76416 Answers
SOURCE: Where is the set up button On ur5u-8780l-twsa???
It is the Prog UP button. Look for it.
Posted on May 01, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: UR5U-8780L DVR remote won't work with Hanspree HSG1102 TV.
no, this is common with remotes, if they program for another unit key features may be missing. Look to see if remote has a search mode that allows you to try each and every code it has one at a time.
Posted on Nov 06, 2012
stevenbkelle
stevenbkelle
SOURCE: Universal Remote: UR5U-8780L - Not Working and CBL Button Constantly Lit
press cable and record buttons at the same time and wait for all the lights to flash in sequence then let go. this will reset remote to factory defaults. then reprogram remote with codes for each device.here is a site for codes. http://www.universalremote.com/resources/pdfs/UR5U-8780L_UR5U-8790L.pdf
Posted on Apr 14, 2013
W.L.
  • 2509 Answers
SOURCE: Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Posted on Nov 13, 2014
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
Mic won't work at auxiliary mode
On the remote control, there is a blue "Magic Mic" button. Press on that your mic will turn on in any mode.
Just joking but I've been mad about how bad this LG home theater system is. It can only play extremely limited video files and turn off the mic in AUX mode. So the answer is you really can't do that. Buy a mixer instead.
Jan 19, 2013 | LG Audio Players & Recorders
I have a scosche ipod connector with an on/off switch on 03 accord but i cant get the stereo to change to aux mode. I repeatedly hit the cd/aux button but it won't switch to aux mode and play mu
Have you tried resetting the stereo?
Disconnect the negative of your battery, wait at least 30 seconds then re-connect it.
That will reset your radio back to factory settings.
Feb 08, 2012 | Scosche Industries Car Audio & Video
Samsung ht-c653w will not give me any sound at all from my digital audio in or my a/v input. (trying to hook up my ps3) But when I hook up the hdmi, the audio is fine for any dvds I play. think it's...
Have you selected the AUX IN?
AUX2 : Connecting an External Analog Component
Analog signal components such as a VCR.
Connect AUX IN 2 (Audio) on the back of the product to the Audio Out of the external Analog component.
Be sure to match the colors of the connecting jacks.
Press the FUNCTION button to select AUX 2 input.
The mode switches as follows :
DVD/CD ? D.IN ? AUX 1 ? AUX 2 ? USB ? IPOD ? FM.
Jun 05, 2011 | Audio Players & Recorders
Yes, also.... I am trying to use my AUX input but "AUX" is not an option on the Source menu. The only options are tuner and CD.
Make the audio only show the time no sound. Try pressing it off and then press a button not source. Then go through the settings by pressing the large round button there should be an option called aux a set that to on.
Feb 06, 2011 | Sony XPLOD CDX-GT200 CD Player
How do you work the aux input? im trying to connect my ipod to through an auxilary cord but im not getting any results?
I have the answer for this problem...finally! This is by far the dumbest instruction manual ever. Here goes:
while in standby mode, push and hold down the menu button until the display changes. Once the menu is up, toggle thur (using the am/fm toggle) until you come to AUX OFF, now toggle it to AUX ON. Exit the menu. Plug in your ipod and push the SRC button until AUX is displayed and enjoy.
Oct 23, 2009 | Kenwood KDC-MP2035 CD Player
Samsung z310
You have to press the AUX button and set the HTS unit to D. IN (DIGITAL IN)
AUX 2 only works for the regular red & white audio cables.
Hope this helps!
Jun 27, 2009 | Samsung HT-Z310T Theater System
Cannot get dvd to play through tv
Check Your Remote For A Tv/Video Button.
Jan 22, 2009 | Televison & Video
AUX????
IS THERE A FUNCTION BUTTON IFSO PRESS IT REPEATEDLY UNTIL YOU GET TO AUX ZAZWPX
Jun 06, 2007 | Sony CMT-EP515 CD Shelf System
Car Audio & Video Logo
177 people viewed this question
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
