SOURCE: Radio volumn goes down when braking
What it is called is (speed sensitive volume):
The radio volume automatically adjusts according to vehicle speed to compensate for road and wind noise. PRESS THE TUNE SELECTOR UP/DOWN OR SEEK LEFT/RIGHT TO TURN OFF OR SELECT RATES 1 THOUGH 7. 7 COMPENSATES THE MOST VOLUME AT HIGH SPEEDS.
I hope that this works for you. Please let me know if you need any more help with you 2006 focus
Nikki2913
SOURCE: how can i turn the volumn up & down using the keyboard
The keyboard controls are run by the quickset utility
Fn+ Page Up increases Volume
Fn+Page Down Lowers Volume
Fn+ End Mutes/unmutes
SOURCE: IPOD touch volumn will not stay up, alway goes back to 0.
This happened to me all i do is turn it off completley (not on sleep) and then it works
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
SOURCE: want to restore back to
First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard
drive utility screen. The key command differs depending on the model
Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in
System Recovery. Verify that you want to continue the process by
clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been
completed. You will be prompted to enter information such as the date,
time and language preferences.
Feel free get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba laptop.
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
The V-Chip is bypassed by holding the zero key on the original remote hand unit, and at the sane time holding down the volume down on the front of the TV set. This should reset the oide so you can enter a new one.
OK.
