Question about GPX Audio Players & Recorders
How do I put the belt back on my GPX s7794 turntable?
4 Suggested Answers
ABRsvcs
  • 4234 Answers
SOURCE: KM837 manual to fix belt on turntable
IF the belt fell off, it is likely that the belt is stretched and needs to be replaced. Use a couple of pencils to open up the belt and beasure the length. The belt should go around the two pencil erasures forming an oval. Use that measurement to determine the belt size and purchase a replacement belt. The belt will go around the platter and around the motor hub.
Dan
Posted on Feb 03, 2009
micmor100
Morne Olivier
  • 257 Answers
SOURCE: turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
Posted on Jun 12, 2010
Andy Turner
  • 910 Answers
SOURCE: I'm trying to change the
Are you sure the Model No. is correct?
Posted on Apr 23, 2011
gopakumarg43
  • 76237 Answers
SOURCE: philco turntable belt
See this video. I might help you.
Posted on Apr 24, 2012
How to put the belt on aiwa stereo full automatic turntable px e855
Lift off the rubber cover. On some turntables, you can pull the whole metal platter straight-up now. Put the belt on the outside of the bottom of the platter and drop platter back into the turntable base. Do NOT put the rubber cover back on yet. There should be one or two openings in the platter where you can see the pulley for the motor. Slowly rotate the turntable platter until the opening is over the top of the motor pulley. Now use a nail file to gently pull the rubber belt over the pulley. It should spin freely now. Now put the rubber cover back on and try it out. Belts are available from MCM Electronics and over online vendors. Let me know how it goes. Good luck.
Aug 16, 2014 | Audio Players & Recorders
How do you program the cd to the GPX home stereo system
How do you program FM stations on the old model GPX s7794 model. I do not have a remote. Thank you!
Dec 19, 2010 | GPX HM3817DTBLK Shelf System
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Drive belt on Sony turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Sep 07, 2008 | Sony PS-LX250H Turntable
Optimus 1000 belt drive automatic turntable
- OPTiC
www.1200s.com
Aug 17, 2008 | Audio Players & Recorders
Turntable drive belt replacement
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Nov 27, 2007 | GPX S7799 Shelf System
118 people viewed this question
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
