Question about Zeiss Science & Laboratory
"incorrect button pushed by patient" pop up on the screen of our Zeiss Humphrey field analyzer mid way through a test and patient DID NOT push anything other than the patient response button
Posted by Nicole Kendrick on
Gep Pep
    Habit-Forming:
  • 54 Answers
Call a repair tech from Zeiss.
Posted on Apr 18, 2019
5 Related Answers
Anonymous
  • 71 Answers
SOURCE: Black Box on Screen
you have to turn OFF cc - closed caption - in the menu
Posted on Apr 29, 2008
Anonymous
  • 171 Answers
SOURCE: light and blower speeds malfunctioning
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Anonymous
SOURCE: Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Posted on Nov 06, 2008
Anonymous
SOURCE: Garmin Street pilot 2720 touch screen not work.
Did you ever get your touch screen to work mine stopped working also i have the 2720.
Posted on Aug 27, 2009
Anonymous
SOURCE: Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Posted on Dec 18, 2009
Why no blind spot dectected
The two most common problems when trying to find a blind spot are: A.) Forgetting to patch the eye, and B.) Choosing the correct eye in the machine itself.
Dec 03, 2015 | Zeiss Humphrey 740 Visual Field Analyzer
How do I hook my external laser printer to my humphrey 740?
In the user manual they list some compatible printers that have a 25 pin parallel connector. We use Lexmark Optra E312L with good results. Once you hook it up, you have to go into one of the setup menus to port it over. The user guide tells the procedure.
Oct 08, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How do I fix the pointer on the touchscreen to be where you touch
You sjould press the patient button and the same time turn it the instrument on keep in button press until you see in tje display the calibration message of the touchscreen
Oct 03, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
CAN THE LIGHT BE TURNED ON IN THE ROOM WHERE THE TESTING IS DONE?
Yes it affect all tje instrument calibration when it is turn on, and when you have patient test the result is afected because the patien has light for the bavk and he is not able to see all the diferents type of lights
Sep 18, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How can I fix my screen ,will not show anything on the field analyzer 740i? Help please
Did you move the brighness control. It is on the right side of the equipment. If not, it could be the video board inside of the equipment
Aug 05, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Why does my zeiss humphrey visual field machine keep shutting down?
Sounds like a heat, thermal issue. You may have a non- functioning cooling fan somewhere inside. There are several of them so don't be fooled if you hear one of them running. Same issue happens with CPUs on PC computers. Will suddenly shut off if too hot.
May 24, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Science & Laboratory Logo
588 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
