Question about Acer Tablets & eReaders
Non of the apps on my acer tablet are working , I have gone through all of the updates and restarted the tablet multiple times
Posted by Tanzinagh Beadell on
Jessica Gallery
    Habit-Forming:
    New Friend:
  • 95 Answers
Might want to contact them -https://www.acer.com/ac/en/US/content/support
If you don't mind losing all you have saved on it you can try a factory restore- It will delete everything!
Factory / Hard reset / Password Removal
  1. Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option.
  2. [SD Image Update Mode]
  3. wipe data/factory reset.
  4. Yes - delete all user data.
  5. Reboot system now.
  6. Your tablet will reboot and go to the Welcome screen.
Posted on Jul 12, 2018
3 Related Answers
BrikimG
  • 31 Answers
SOURCE: How do I make the launcher3 from stopping every time I turn on my tablet and make my Google play app work
That is what happens when you have no network connection. Are you sure you are connected. Also are you sure you are logged in to Google?
Posted on Dec 27, 2014
Steve Butterworth
  • 938 Answers
SOURCE: Multiple apps are not responding even after being reported and factory reset.
What's the warranty on this product?
I don't know how old your tablet is, but if it's fairly new I would suggest that you go back to the retailer and reject it "as not fit for purpose ". If it's less than a few months old this should work. The closer you are to expiry of warranty the more forceful you will need to be. This approach works fairly well in Europe and the UK.
Posted on May 06, 2015
rongg
  • 97 Answers
SOURCE: How to fix my Facebook app on Android tablet. No longer looks or preforms like the normal app. Think malware is involved.
A few suggestions:
1. Ensure you are using a good (fast) wifi connection.
2. Make sure there are not too many apps running in the background on the tab at the same time (using resoures). Close unused/unneeded ones.
3. Check for updates to your tab's system software. If available install the latest update.
4. Log into Facebook with a browser app instead (i.e. chrome, firefox, etc.). Check if there is a problem after 30 min. or so accessing Facebook this way.
5. A full system reset will probably fix the problem (unless there is also a hardware component problem with the tab). But it is a lot of work to reinstall apps, accounts, etc. (... consider only as a last resort).
Posted on Aug 25, 2015
Keep getting message Google play store has stopped I tap ok and it goes away but I can't get in to play store.I have Acer tablet.
it depends what android software is and your games and apps try and update your tablet to see if it works
Mar 11, 2018 | Acer Tablets & eReaders
I just updated my iPad mini 4 to the latest iOS. When I play videos on the google and safari app the audio works but the actual video won't play
If you remove the update does it play? Have you gone to the Apple site and asked others about this issue.
Sep 21, 2016 | Apple iPad Mini
A few suggestions:
Aug 25, 2015 | Tablets & eReaders
Why when I save apps to my SD card then turn off my tablet and turn back on all my apps are gone from SD card, where are they?
Often, the makers of the app want to protect their intellectual property. Other times with an app like Frostwire, if you download something like an illegal copy of a movie, they intentionally delete the movie ( or music etc.) When and especially because you uninstalled their app. Obviously however, if you lose data that you shouldn't when restarting your device, then more than likely the app is flawed. This is why they update certain apps so often- to fix the bugs. In your case, it depends on what you stored "off device". Also, it could be a problem with your phone. Check the problem against another phone.
May 23, 2015 | Tablets & eReaders
Get a full screen on face book please
Suggest to first try logging into Facebook using the browser on your tablet instead of the facebook app. If that display is normal in size ... it's probably easiest to
(1) uninstall the Facebook App (Control/Settings/Apps);
(2) reboot the Tablet;
(3) Restart the Tablet and Go to the Google Playstore ...reinstall the Facebook app.
Mar 08, 2015 | Samsung Galaxy Tab 2
Why did google play store stop working on my NuVision Android tablet? It was working fine.
Try to uninstall updates of play store.. Settings>apps>Google play store>uninstall updates..
Feb 11, 2015 | Tablets & eReaders
Certain apps that need wifi don't work even though I have perfect wifi signal. I've already restarted my iPad mini, charged it, and turned on and of the wifi a few times, but that didn't help
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
Dec 30, 2014 | Apple iPad mini 7.9" 16 GB Wi-Fi 4G White...
Compaq tc4400 suddenly turned into non tablet pc (pen & touch gone)
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=compaq%20tc4400&searchtype=s-002
this is where your find the moel drivers for tablet , there are two available , so please read before installing.
Nov 27, 2013 | Compaq tc4400 Tablet PC
Wifi won 39 turn
you have to do is be root and install an app called root exploret
and go to system / app here find the application to be deleted and if you go back to the menu and restart the tablet is removed and you can download the update hope you reserve
Aug 31, 2013 | Iview Cyberpad 900TPC 9-Inch Tablet
Tablets & eReaders Logo
69 people viewed this question
Top Acer Tablets & eReaders Experts
Marvin
Marvin
Kurt Bresler
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
