Question about Braun Health & Beauty
How can I hard reset a Braun 790cc-4 Type:5692-612? The notification for the cartridge replacement after 18 months came up, and the battery and hygiene level indicators stopped working.
I have a Braun 790cc-4 Type:5692-612. A few weeks ago, it showed the Replace - 18 months message on the LCD. The problem is that the battery and hygiene indicators stopped working. Resetting the machine doesn't change anything.
Posted by Behzad Samadi on
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: MP150 Error code 4 and 5
Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Posted on Feb 11, 2008
Anonymous
SOURCE: Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
Posted on Jun 07, 2008
Anonymous
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
Anonymous
SOURCE: One day the Braun 7 790cc simply did not turn on.
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
  1. The black rubber/plastic cover on the back will pop off if carefully pried apart from the gray plastic. Start around the middle of the razor body.
  2. Once the black piece is removed you will see four screws holding on a plastic cover. These can be removed with a sharp flat head screwdriver.
  3. The plastic cover can then be pried from the razor body. Be very careful though as there is a rubber seal around this to keep water out. I broke mine.
  4. Inside you will see a somewhat large red battery with prongs on either end. Pop it out of its location and wait a couple of seconds. Press it back into position and you should hear a click for both ends.
  5. After this, I took all of the flat copper pieces and gently bent them towards myself (without making them touch of course... this could cause a short and potentially cause the battery to explode).
  6. Replace everything and see how it works... Hopes this fixed it for you and saved you $100-200. Have a good day!
Also... I am not responsible for any damages that may occur.
Posted on Feb 02, 2010
Anonymous
SOURCE: My portable air conditioner, model
you should drain the water from the unit by removing the plug in the back and tilting the unit back to drain water and unit will start right up
Posted on Jul 21, 2011
Side burn trimmer won't stay closed on 790cc braun razor .
Almost certainly, the trimmer is broken and will need replaced. The part and replacement video instructions can be fount at shaveroutlet.com
Braun Pulsonic and Series 7 Shaver Trimmer Assembly
1helpful
Braun dosent charge
Hi, Replace the battery it is faulty. After many charges the battery will not charge any more its called internal discharge Repace it and you are good to go.
1helpful
2answers
Braun Series 7 790cc: Battery is fully charged. Turn on the razor and it runs for about 1 minute and will just stop. Push the on button and it will run for 3-5 seconds and stop again. But, if you take off...
Hi, My guess is that the battery needs to be replaced with a new one. After many uses the battery will not charge properly any more. (internal discharge) Replace ,Replace ,Replace.
2answers
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
2helpful
My Series 7 790cc razor became really loud after a
Your shaver came with a 2 year manufacturer warranty. Follow the warranty istructions in the user manual that came with the shaver or call Braun at 1-800-272-8611
Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
