Question about Baking
How many cake mixes does the wilton puppy cake pan 2105-2430 take and how long do you cook it
Posted by Mary Barnhart on
Jason Alden
    Habit-Forming:
    New Friend:
  • 61 Answers
Bakery boxes nowadays are very conscious about the boxes made for their brand of the business. It's not only making the look attractive but giving them a product related beautiful look. You can't afford to ignore colorful and attractive paper boxes.
Posted on Oct 08, 2018
Kami
    Novelist:
  • 307 Answers
Slice-heaven-com will download the original instructions for a fee. You might be able to wing it without them, knowing that Wilton recommends filling large, deep pans only half deep. Fill it with water first, then pour water into a large measuring vessel to gauge how many cups of cake batter you will need at that depth. The average cake mix makes about 4 cups batter, but they vary. You could always just prepare 2 boxes and reserve any excess for another use. As for baking, this pan will probably take a little bit longer than a 9 by 13 by 1-1/2 at 350 F. Maybe you could add 15 minutes and check on it. Do not open the oven if it is clearly not done.
Posted on Sep 18, 2018
4 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: I have a GE Microwave/
I would check GE's website, they probably have a forum where you could get a better answer.
Posted on Jun 10, 2008
SOURCE: if I make a chocolate cake with a store bought mix, can I double it? Ie can I buy 2 and cook them together at the same time?
Sure you can. Just follow the instructions carefully ie if one mix calls for 1 cup of oil, use 2 cups for a double batch. But DO NOT double the cooking time. It will take longer to cook a double cake than a single but probably only around 10 - 15 minutes more. So keep a careful eye on your cake.
Posted on Feb 28, 2013
melicruz195916
Melissa Cruz
  • 79 Answers
SOURCE: If I cook a store bought cake mix, is it ok to add things to it such as nuts or chocolate chips?
Yes its fine! Raw mixed nuts comes in varieties at Fredlyn Nut Co. almost in all forms. Get exceptionally healthy & versatile raw nuts by just calling on 888-822-6887.
Know more here: Buy Fresh Raw Mixed Nuts Roasted Frozen Nuts By Fredlyn Nut Co
Posted on Sep 11, 2015
vince
  • 1234 Answers
SOURCE: How many cups of batter do I need to fill Wilton heart cake pan model 503-407? Thanks.
go here watch how to video on the site....
http://www.wilton.com/heart-tasty-fill-pan/2105-157.html
Posted on Feb 10, 2018
Hi. I want to put a sponge cake batter in a Wilton cake pan I always flip my sponge cake upside down and use an angel food pan. How will I get my sponge cake out of the Wilton cake pan after cooled.
Most sponge cakes containing baking powder can be baked in standard round cake pans that are greased and floured. I prefer nonstick baking spray, myself. Without leavening, or if cake is delicate, it might help to line the bottom of the pan with greased parchment and leave the sides ungreased. Simply run a butter knife around the sides to release finished cake.
Sep 17, 2018 | Baking
Feb 10, 2018 | Kitchen Appliances - Others
Does anyone have Wilton elephant cake pan instructions
The pan style has been discontinued but you can still download a copy of the instructions in PDF right here: http://demandware.edgesuite.net/aawa_prd/on/demandware.static/-/Sites-wilton-Library/default/dw76d09c81/paninstructions/2105-0576-ElephantPan.pdf http://demandware.edgesuite.net/aawa_prd/on/demandware.static/-/Sites-wilton-Library/default/dw76d09c81/paninstructions/2105-0576-ElephantPan.pdf
Sep 01, 2017 | Baking
Do Wilton pans take longer for baking than typical recipes call for? My cakes are sinking during cooling even after baking 10-15 longer than recipe calls for.
I am not familiar with Wilton pans, but as a former professional baker, the main reason for cakes sinking, after baking, is under or insufficient baking. The structure of the cake, which is aerated by the baking powder releasing carbon dioxide to "push it up" or by the inclusion of air during the mixing process, (as in egg sponges or madeira cakes,) needs to be fully set to ensure it stays put as the cake cools. If the structure is not fully baked, as the cake cools the raising agents dissipate and the cake collapses.
Collapsing during baking is caused by fundamentally different reasons, usually as a result of unbalanced recipes.
Hope this helps.
Jul 18, 2017 | Baking
Where can i obtain the cake decorating directions for a wilton teenage mutant ninja cake pan?
Dear Dennis,
I found a site for you to look at to get cake decorating directions for Wilton TMNT's cake pan.
Go to: slice-heaven.com
and in the search box, type: teenage mutant ninja turtles
then look over and choose your option.
I found other sites but none as cheap or easy.
May 02, 2017 | Baking
Can i cook two boxes of cake mix together in one ten inch square tin, to make a large cake?
According to Duncan Hines - no. One box of mix will cook properly in a 10x2 pan assuming it is the same height as your regular cake pans. Here is some conversion info that I copied from one of their mix boxes: 1 box of mix yields 5 1/2 cups of batter. 5 1/2 cups can be cooked in a 10x2 pan and should take about 40 - 50 minutes. You can make 2 cakes and stack them for a big cake but all that batter in one pan probably won't cook right. Two boxes of mix need a 15 x 2 round pan or an 11 x 15 x 2 rectangle pan. I hope that helps!
Feb 26, 2015 | Betty Crocker Cake Mix New Betty Crocker...
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
Baking Logo
719 people viewed this question
Top Baking Experts
Don A
Don A
Bill Boyd
Kami
Are you a Baking Expert? Answer questions, earn points and help others
