Canon ir 7105
Email Canon Support to request information.
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-7105/imagerunner-7105?tab=
SOURCE: i have this machine Canon IR 7105 B&W
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
SOURCE: error code for canon ir
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
