Defiant led light fixture, Model #DW9519GY-A
First, I'm not a Defiant tech.
* Check your warranty. Call for support.
*** following is for information only ***
* May be in "Test" Mode. Check the mode switch.
* Setup Demo; https://www.youtube.com/watch?v=XBaHo_44aps
* Specs on Home Depot; https://www.homedepot.com/p/Defiant-Wall-Pole-Mount-Area-Light-Outdoor-LED-with-Dusk-to-Dawn-Control-DW9519GY-A/207105761
* Please note the question answer section on Home Depot site
Aloha, ukeboy57
Posted on Jul 11, 2018
SOURCE: I have a 2006 KDF55E2000 Grand Wega. The lamp
yes sony part number f-9308-750-0
philips bare lamp part number phi379
Posted on Sep 02, 2009
SOURCE: I am trouble shooting an emachine T2898.
Well I can't exactly get you the layout of the motherboard because I don't know what motherboard you have. Find out what model the emachine is and Google it. You'll find everything you need out there. Or you can e-mail the model name to me and I'll help you out: [email protected]
Posted on Sep 16, 2009
SOURCE: I have replaced the lamp
Reinstall lamp and make sure lamp cover has fixed in its position securely after lamp installation.
Lamp cover is first thing that you remove from tv cabinet to replace lamp in tv.
Thanks.
Posted on Oct 12, 2010
SOURCE: keeps frezing up have tryed all trouble shooting
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Posted on Jul 24, 2011
SOURCE: hampton bay exterior wall mount light fixture blinks after installation
If this is a unit that is supposed to turn on when it's dark, then the problem is that the sensor is "seeing" too much of it's own light. That is, when it get's dark it turns on, but the light it provides is telling the unit that it is sunrise and should be turned off. Find the sensor and cover it with tape, this will keep the light on. Now try to figure out where the brightness is that the sensor "sees". It may be a reflection from a nearby white surface. You might be able to redirect the lights (if they are reflector bulbs), or you might be able to paint the reflecting surface a brighter color, or you might be able to fashion a visor out of tape to shade the sensor from the reflected light. Good luck!
Posted on Dec 03, 2012
Oct 02, 2018 | Solar Home Security
Jul 09, 2016 | Home Security
Apr 05, 2016 | Defiant Flood Lights. 180 Degree Outdoor...
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
256 people viewed this question
