Ovens Logo
Question about Belling Ovens
Belling stove door wont close properly how do I adjust the hindges.
Posted by Alison B on
Mark Cheong
    Master:
  • 791 Answers
First, I'm not a Belling representative.
* Check your warranty.
* contact for service; https://www.bellingspares.co.uk/help.pl
*** Following for information only ***
* Could not find a specific adjustment for this brand of door. Looks like it should just fit. Miss aligned doors is an indication the hinge is broken and needs replacement. There are very few "adjustments" on other brands too.
* Replacement; https://www.bellingspares.co.uk/main-oven-door-hinge/product.pl?pid=1497832
* Removing door; https://www.youtube.com/watch?v=wXxLguoUnMg
* Removing door (different models); https://www.youtube.com/watch?annotation_id=annotation_1309719061&feature=iv&src_vid=wXxLguoUnMg&v=hSzc4Uqbbr8
* "Band Aid" adjusting door closing (Westinghouse); https://www.youtube.com/watch?v=l5D3wtlL3f8
* Replacing Hindge; https://www.youtube.com/watch?v=Uy2s5EG5GiM&t=122s
Aloha, ukeboy57
Posted on Jul 11, 2018
RudeRude
    Master:
  • 526 Answers
Open the door and readjust them using a philips head screw driver.....
5 Related Answers
Anonymous
SOURCE: adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
Posted on Dec 19, 2007
Anonymous
  • 89 Answers
SOURCE: STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
Posted on May 26, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Eurogas oven door
If it is a drop down door, then generally speaking it is the door hinges nthat need replacing, as they are mot usually adjustable.
Hope this helps.
Posted on Jan 06, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: can i adjust the hindges as my door does not seal
It is usual to be able to adjust oven door hinges.
Normally the only solution is to replace the hinges.
Hope this helps.
Posted on Jan 12, 2010
Testimonial: "very helpful thank you."
Anonymous
SOURCE: both oven doors do not
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Posted on Jan 22, 2011
We have a Westinghouse Polaris free standing oven and the door does not seal properly, huge waste of money heating the oven to have theheat escape! grrrrr ! can the door be adjusted to close properly?
this is usally one of two things the metal is stressed at the point where the hindges go into the stove remove door and flatten with a piece of wood and a hammer only if you can see the metal is bowed out,also the actual hindges may be worn and have exccessive play in them
1helpful
Can i adjust the hindges as my door does not seal closed i have a delonghi pro cooker ess903 thanks colin
Hope this helps.
Eurogas oven door
Hope this helps.
Jan 06, 2010 • Ovens
Oven door is hinge-bound. Does not close completely. how do I adjust it
Get on your knees in front of your stove. If there is a gap on the right side you will want to hold the left side in while pulling on the right. Don't try to do it all at once. do a small amount and check your fit, Till closes proper.
hope this helps you.
Sawdust46
Aug 21, 2009 • Ovens
4helpful
May 26, 2009 • Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
My stove
Usually when an oven door will not close properly, the door hinges will need replacing
Adjusting the oven door hindges for a snug fit
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
