Question about In Microwave Ovens
SOURCE: i was cooking 4 potatoes for 14 minutes then put
yes their is a internal fuse 15 or 20 amp inside usually behind the control panel. if you are some what handy then yes its worth fixing. fuse can be purchased at lowes or home depot.if you are paying to have it fixed and thats the only thing wrong you are looking at around 70-140 depending on were you live in home service if you take it in could be 30-75.dollars. if u do it yourself then 3.99 for fuse. give it a shot. remove top grill . then you will have one screw holding top of panel remove and look for a ceramic fuse. 1st unplug the unit. hope this helps.
Posted on Sep 16, 2009
SOURCE: Microwave Model WES1450DM1BB I boiled 4 cups of
Owners of a GE WES model
might want to look at this
blog post.
I'm sure the magnetron overheated and tripped the magnetron's thermal cutout.
I'd strongly suggest taking it back if you can.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Posted on Dec 26, 2009
SOURCE: Placed 3 ears of corn
What this indicate is that the time of the oven will need to be reset
What you are to do to fix up this problem is to follow this instruction bellow
Press
the "Timer set" button and a timer indicator light will illuminate. If
you allow five minutes to pass while setting the timer, the light will
go off and you will have to press "Timer set" again.
Choose
the "Hour" button to select the number of time you want to set; push
the arrow up until you reach the number of time desired. Select the
"Minute" button and move the arrow up to add minutes or down to
subtract minutes. Press the "Start" button to begin the countdown to
the amount of time selected.
Press
the "Timer off" button to make the timer stop. When the time you set
has been reached, the timer will let you know with an end-of-time tone.
Most Whirlpool models will also give you a timer-finished tone every
two minutes thereafter.
thank you and thanks for using fixya.
Posted on Sep 15, 2010
