Question about Danby Dishwashers
My Danby Silhouette dishwasher is showing error 006
Posted by richard on
4 Related Answers
Anonymous
  • 154 Answers
SOURCE: Error code E 04 was
most error codes are to do with the main board or a switch board and ussually need to be replaced. If you have the manual for it they normally have the error codes and there meaning in them. If not in the manual you should ring your nearest repairer and give them the make model and error cdes and they can ussually tell you what it is from.
Posted on Jul 22, 2008
chaos900rr
chaos900rr
  • 20 Answers
SOURCE: Danby silhouette dpac120061 manual
Try to google the manufacturer and model number, sometimes the manufacturer has a downloadable manual online. Otherwise, you may have to contact Danby to order one.
Posted on Jul 15, 2012
SOURCE: danby silhouette dwc276bls e2 error solution
Hi There,
The E2 error codes indicates there is an problem with one of the sensors.
Please contact our customer service department for information on repair.
1-800- 26- Danby
Thanks!
Posted on Jul 19, 2012
ve4tjr
TimR
SOURCE: My danby 22" countertop dishwasher wont **** water
Kept on getting this same code, and pump was very loud. Discovered that drain hose can get crimped or flattened like a garden hose at the rear of the dishwasher, causing the pump to work very hard to drain the tub. Especially since the dishwasher is on a counter top and gets moved from everyday use, and pushed into the wall. Pull the washer away from the wall, and reshape the hose by hand to fix. Once crimped it wants to go that way again, might use some hose clamps to hold the house open at the flattened area.
Posted on Oct 13, 2013
Door latch
Umm. Try forcing it open with your hands. I AM NOT RESPONSIBLE FOR ANY AND ALL DAMAGES DONE TO YOUR APPLIANCE.
Oct 20, 2013 | Danby DDW2406 Stainless Steel Built-in...
Danby silhouette dwc276bls e2 error solution
Hi There,
1-800- 26- Danby
Thanks!
Jul 19, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Jul 15, 2012 | Danby Heating & Cooling
Need instruction manual for Danby Silhouette dehumidifier DDR583R for explanation of icons
Well can't seem to find your particular model but they have what looks like yours
http://www.needinstructions.com/search/?q=Danby+DDR600R+Silhouetteumidifier+MANUAL&page=3
Jul 17, 2011 | Danby DDR600R Silhouette Dehumidifier
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Hy there...i just cant get rid of error 7,what should i do? thanks
I have the same problem E7 shows up we played with nothing happened :(
Apr 21, 2011 | Danby DDR600R Silhouette Dehumidifier
Error code E 04 was on screen for our Danby Silhouette 12000 BTU Air Conditioner Model DPAC120061 and now it won't run properly
Jul 22, 2008 | Danby Heating & Cooling
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
Danby error code 002
I spoke with Danby, and this error indicates the fact that the dishwasher is unable to fully drain. Likely causes are a kink in the hose, hose is too high on the drain pipe to drain, or, the pump motor is dying.
Seeing as mine's been mounted without fault in the same place for 2 years, I think I can tell you which one I have.
Dec 22, 2007 | Danby DDW2406 Stainless Steel Built-in...
Dishwashers Logo
145 people viewed this question
Top Danby Dishwashers Experts
Michael Thomas
Michael Thomas
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
