Old and new battery same problem
Even though the charger is new, I would check the charger with a meter to check its polarity just in case.
Testimonial: "I had a older charger with just red, yellow, and green lights and the red light would come on so I thought battery was bad(battery was about 2 or 3 yrs old and I haven't rode that much). I had been keeping battery hooked up to float mode old charger showing green light. When bike wouldn't turn over starting I knew something wasn't right. When first connecting old charger it showed trouble red light. I could unplug and then plug in again and it would show green."
SOURCE: Installed new battery in 2001 Nissan Quest backwards
WOW, your lucky it didn't blow up and start the car on fire. there is probably serious damage to the entire wiring system.
start checking fuses hopefully its just another blown fuse if your lucky
but if all the fuses are good, you probably fried something like the computer or ignition module and probably the radio
hopefully its something simple and cheep but don't be surprised if you have to shell out some cash to replace the computer
SOURCE: reversed polarity on 2000 mazda millenuim, now my car wont start
who ever made the new battery has accidently mad eit with reversed polarity there is a way of changing this i think you just charge it with the reverse polarity minus to positive ect
SOURCE: i need to install a starter solenoid on a 1990
Maybe you bought the wrong part, take the old part to auto parts store where you bought it and compare it. on this older model vehicles it is unusual for parts no to be the same.
