Question about Mercury Boating
Water psi for mercury xr6 outboard motorwhen running
Posted by ray winstead on
Finding year from a ssrial number on a mercury out bord
go google and type in--- mercury outboard serial numbers -- there are sites that listhp against serial numbers against year of manufacture
while you serial number may not be listed they state that the beginning of the number to the next changing number is the year of make
for example ---4261012 to 4302999 ( next number 48103665,year 2002) may be year 1999 so your number would be a 1999 model
The information provided will take a bit of understanding as it appears that the manufacturer changed the method a number of times
talk with a mercury / mariner service shop as they will have the information on hand
Sep 26, 2016 | Sierra Tilt/trim Motors, Outboard...
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
What year is my mercury outboard searial no 3768233
Check here, you'll need the horsepower and lookup the serial-number range...
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 31, 2014 | Mercury Impeller, Water Pump - for...
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
Mercury 850 Thunderbolt outboard
call mercury don't think they had a place for water pressure hose in the 70s on there motor
Aug 30, 2013 | Boating
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
I am getting an alarm on my 1992 xr6 mercury. HOW CAN i TELL WHAT IIT IS
check its not overheating , put your hand on the engine ! oil level low ? when does it happen ?
May 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Overheating on a mercury outboard xr6
ignition timing, valve timing if valves
air /fuel mixture too lean, incorrect pitch prop overloading the engine
Take it back to where the new power head was fitted and have them sort out the problem
Dec 23, 2017 | Boating
Boating Logo
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
