Question about Home Security
Can I get a Manuel for a Bunker hill Safe model #45891?
Posted by Martha Mainella on
Terry
  • Home Security Master
  • 11,377 Answers
5 Related Answers
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
Posted on May 16, 2009
Anonymous
  • 101 Answers
SOURCE: i bought a safe from a garage sale and cant poen it
I know Harbor Freight sells some of their products and you can download the users guide from their website it should help you get it working. Good Luck with it!
Posted on Aug 06, 2009
Anonymous
  • 6 Answers
SOURCE: changing digital combanation on safe
Manual for bunkerhill safe , how to program and specs:
http://www.harborfreight.com/manuals/93000-93999/93575.pdf
No Known default combination.. Sorry!
Posted on Oct 29, 2009
Anonymous
  • 6 Answers
SOURCE: bunker hill safe model no.45891 bought used, can't
Safe has Key lock hidden on it? Contact Harbor Freight with serial number, to try and get new key. Once opened follow these instructions at:
sbmg1
sbmg1
  • 3 Answers
SOURCE: bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Posted on Aug 30, 2012
What does the key for a bunkerhill safe p 45891 look like and where does it go into?
Hello, Richard -
The image here:
https://www.terapeak.com/worth/replacement-keys-manual-for-bunker-hill-electronic-digital-safe-model-45891/162049295398/
shows the keys for the Bunker Hill safe model 45981. The keys are in the center, lower part of the image.
The image of the front of a different model Bunker Hill safe from the owner's manual here:
https://www.manualagent.com/harbor-freight/0-19-cubic-ft-electronic-digital-safe/product-manual-2
shows here the key "slot" is located.
Best wishes.
Feb 06, 2018 | Home Security
Is bunker hill safe 45891 fire & water proof
Per the manual, the safe is not fireproof. I will also guess that it is not waterproof, based upon the construction of the safe.
Sep 23, 2014 | Computers & Internet
How do i get into my bunker hills digital floor safe 45891 when i have lost the combo and the keys?
Try banging on the top of safe with hand, rubber hammer, regular hammer with board on safe to spread the energy, etc. while turning the knob at the same time. Sounds silly but worked for me. Sellingdj......
Jun 16, 2014 | Check Point Network Adapter
I have a bunker hill safe #93575, the battery is getting low. is there any thing i need to know about changing the batterys
Change batteries ASAP because if your batteries die you will be unable to get into the safe without the key. The batteries are located inside the safe. If you can't open the safe, you can't replace the batteries!!!
There are NO replacement keys available for model #45891. We've tried. I would NOT buy this safe again for these reasons.!!!
Nov 08, 2011 | Check Point Network Adapter
Bunker hill safe model no.45891 bought used, can't open. any ideas?
Oct 20, 2009 | Check Point Network Adapter
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
May 16, 2009 | Check Point Network Adapter
Bunker hill digital safe
Dec 19, 2008 | Check Point Network Adapter
Home Security Logo
339 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
