SOURCE: I have a ef 2600 yamaha generator & over the course of a
The fuel pump diaphram has a hole in it.
SOURCE: Can you help me? I have generator yamaha ef 2600.
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
SOURCE: Yamaha ef 1400 generator runs but not producing power
Check the brush holder for worn brushes. If they seem ok then the voltage regulator has failed.
SOURCE: My yamaha 2800 generator will run for 10min then motor gets hot and shuts down
Check oil level and cooling air flow past the cylinder. Are there foreign material like leaves in the air intake?
