Question about Windchaser Heating & Cooling
I am looking for parts for my windchaser PAC9. I need nozzle fitting cover, nozzle fitting and adjustable window panel. where can I get these parts?
Posted by Alfreda Buchanan... on
Andy
    Loyalty:
    Visited the website for 30 consecutive days.
  • 572 Answers
Try any fw webb
Posted on Jul 10, 2018
3 Related Answers
tech4allmen
rey francis basa
  • 666 Answers
SOURCE: Is there a free online
I hope this is what you are looking for http://www.ajmadison.com/ajmadison/itemdocs/User_Manual_PAC9.pdf
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Posted on Aug 01, 2011
randallharre
Randall Harrell
  • 94 Answers
SOURCE: I have a '93 Geo Metro in need of driver door panel and window trim for same. Are '95 interior parts compatible?
Yes. 93 to 98
Posted on Jan 13, 2014
Testimonial: "Thanks! My Metro may get finished after all."
claudeinmo
Claude Kayser
  • 9098 Answers
SOURCE: Need a manual for a Windchime PAC9 Model SA 12059 Air Conditioner, or advise on how to bet alarm light to turn off so unit will work
on the WEB
Windchaser PACR9S Instructions Manual - ManualsLib
www.manualslib.com > ... > Air Conditioner > PACR9S
View and Download Windchaser PACR9S instructions manual online. WindChaserProducts Inc. Instruction and Maintence Manual Portable Air Conditioner ...
Posted on Aug 05, 2015
on the WEB
Aug 04, 2015 | Windchaser Heating & Cooling
My model no. is PACR 93S
This company is out of business, so the parts are not currently available. However many people have visited lowes or home depot and managed to rig up a fix that works sufficiently.
Jun 24, 2015 | Windchaser PAC9 Air Conditioner
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
I have a unit with no exhauste hose conecter and no nozzel fitting covers or a window panel
Sadly this company seems to be out of business and parts unavailable. You can get vent hose at lowes. I attached the hose to a unit with a couple of small metal brackets, zip ties and vent tape. For the window part, I cut a piece of plywood, painted it white and cut a hole for the vent hose. Attached it with zip ties and silver vent tape.
May 24, 2012 | Windchaser PAC9 Air Conditioner
I need a new exhaust hose and fitting for a PACR9 unit. How/where can I get one?
Sadly the company seems to be out of business. I did manage to fashion one using a few parts from lowes. I had to use 2 small metal brackets and some zipties to attach the hose to the unit, then sealed the connection with thick foil tape.
Aug 29, 2011 | Windchaser PAC9 Air Conditioner
I have a Portable Windchaser Air Conditioner and the back filter looks very dusty. Should I replace or clean the filter? There doesn't seem to be a way to remove it without disassembling it. Thanks...
these filters can usually be removed and cleaned by carefully sliding it upwards. Some units they just unclip, pop off with a sligh force. However removing the filter will only expose the evaporator, it is MUCH recommended to remove the entire back cover of the unit to gain access to the condenser and clean both of the radiators.
Aug 20, 2011 | Windchaser PAC9 Air Conditioner
I need a connector for the exhaust port for the WINDCHASER PORTABLE AIR CONDITIONER PACR93S is there anything I can buy at the hardware stores that can replace those parts easily
I used a Plastic plumbing fitting, attached to the ac unit with a small metal braket. Sealed it wth thick foil tape. Sadly the company is out of business and the original flange connectors are unavailable.
Jul 19, 2011 | Windchaser PAC9 Air Conditioner
I need to get an exhaust kit and the adjustable part that goes in the window. Model PAC 9 Any idea where I can get this so that I can use my unit?
Sadly the company is out of business, so you will have to get a little creative like I did. I got what I needed at lowes, some flex duct, a pvc pipe fitting, small metal brackets, zip ties, thick foil tape, a piece of plywood for the window part, and some paint. Good luck.
Jul 12, 2011 | Windchaser PAC9 Air Conditioner
Missing knob for fan, broken grill (top Front) where can I buy parts in Ontario?
Contact Windchaser at their toll free phone number for assistance
The phone number is 1-800-405-2943. You will be directed to a Customer Service Rep. Monday thru Friday, 8:30 am - 4:30 pm PST.
Jun 21, 2011 | Windchaser PAC9 Air Conditioner
I need a adaptor that will allow me to vent my Windchaser Pac9 Model SA12059 through a window. Do you know where I can find one?
Sadly this company seems to be out of business, parts unavailable. You can get a little creative and make the pieces you need from off the shelf parts at lowes. I used a plastic pumbing fitting, some vent hose, two small metal brackets, zip ties, and thick foil tape to seal it.
Oct 11, 2010 | Windchaser PAC9 Air Conditioner
Heating & Cooling Logo
186 people viewed this question
Top Windchaser Heating & Cooling Experts
Marvin
Marvin
Dennis Boxerman
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
