Sewing Machines Logo
B
Bessie Branyon Posted on Jul 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need base software cd for CE250. A machine was given to me and the embroidery software bonus software included +autopunch. 173A227C320245 was broken in half.
Bill Boyd
Level 3:
Top Expert:
  • Sewing Machines Master 53,816 Answers
  • Posted on Jul 09, 2018
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11945806
Points
172802
Try the manufacturer web site for a down load disc for your machine or pdf version down load that you can down load to stick or cd
1 Related Answer
Anonymous
  • Posted on Jan 22, 2013
SOURCE: I have lost my Singer CE250 Embroidery Software
No! The files are encoded with security software that looks for the original cd that is also marked. See CD-Cops.
2answers
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
2helpful
How do you use Singer Futura Editing Software?
Under submenu "Help" you can find different manuals and tutorials that describe all features. "Outline Edit" is intended for modifying the embroidery objects that were created by the native software (for example text blocks or AutoPunch Wizard result). With "Stitch Edit" you can modify specific stitches of any designs.
Main menu->Edit->Outline Edit and Stitch Edit
or two first buttons on the second line of the main toolbar or hotkeys "E" and "X".
3answers
Importing files into futura
Put your images into your pictures folder.Once in the Futura software,go to file,open design browser click on the top and find My Documents, then click on my pictures and they should bring them up.
Create my own designs
Your CE 250 allows you to do very basic digitizing by using Autopunch.
To activate autopunch, click on "create" from the top menu and select "autopunch" from the drop down menu. A new Autopunch wizard menu should open. Click on "next" on the browse to your jpeg file by clicking on "select". Keep on clicking on "next" until you get to the "customize stitch block" menu. Here you are able to remove unwanted blocks or change the stitching order by clicking on a block in the right hand menu and the clicking on the "Remove", "move up" or "move down" buttons.
By clicking on the radio buttons, just below the "move down" button, you can also select between Fill stitch or Satin stitch. When you are happy with your decisions, click on next and click on finish.
That is about all that you can do and autopunch will do the rest. I suggest you import a couple of dfferent clipart images and play around as discribed above to make you familiar with the program. You will also see different results by changing options.
If you are not happy with final results, I suggest you invest in a proper digitizing program, such as Creative Drawings. Visit the at www.drawstitch.com/Creative
Good Luck
Copy of Software
I have the autopunch software. I may help you. (futura ce250)
2answers
Can't load Hyperfonts on my pc
Hello I have the same machine Futura CE250, But I just have the the Autopunch software. I dont know why this situation. What about if you try uninstalling and reinstaling the software? my email [email protected] Best regards and good look.
59helpful
29answers
Futura CE 200 Software Installation Media
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
