If i have a smart tv, do I need a booster for an outdoor antenna, I am planning on a 20-30ft pole, for the antenna
Posted by Troy Thornburg on
Vernon Taylor
  • Televison & ... Master
  • 6,582 Answers
The benefit and functionality of a smart tv is derived as much from a good internet connection as from decent signal strength from the antenna.
The ideal height, type and direction of the antenna depends entirely on the signal strength available where you are and the length and type of downlead cable.
If the signal strength is poor it is generally better to use a high gain wideband aerial designed for fringe reception than to use a lower gain and a booster.
It is worth noting a booster can usefully help increase the strength of a weak but good quality signal but there is little advantage boosting a signal that is both weak and poor quality so it is best to obtain the best signal possible before considering a booster.
A low specification downlead can reduce the signal and gather interference causing a bad signal/noise ratio. Using a booster at the end of such a downlead will boost the interference as well as the signal - the best place for a booster is as close to the aerial as possible and masthead types are produced to avoid those types of problem.
It is best practice to use the highest quality downlead cable - double wrapped air spaced low-loss 75 ohm coaxial cable.
Posted on Jul 09, 2018
3 Related Answers
Gills1
Bill Gilhooly
  • 94 Answers
SOURCE: I recently acquired my grandmothers
I could not find a "RCA model #27F350T", but there is a RCA model 27F530T, and according to the users manual for that TV, it is not Digital ready. You will need a converter box if you wish to continue receiving antenna based broadcasts. Your users manual can be found at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
Posted on Jan 04, 2009
Sulaiman Sarumi
  • 586 Answers
SOURCE: will mounting sdv8622t/27 antenna higher
yes, mounting the sdv8622t/27 antenna higher will improve its reception. The more the antenna goes up, the better the reception it receives. There won't be any interruptions if the sdv8622t/27 antenna goes higher. So, it is better if you mount the antenna higher as you intend.
As for the booster, it is not okay for the booster to stay outdoors. The booster should remain indoor, while the antenna stays outdoor.
I believe this is clear to you now. If you still have any more questions about your sdv8622t/27 antenna, please let me know as I would be please to respond to you.
Yours sincerely.
Elect_Comp.
Posted on May 24, 2011
Vladimir Frolov
  • 2075 Answers
SOURCE: I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Posted on Feb 26, 2015
My tv screen is snowy and I get the prompt: weak or no signal...check the antenna cable connection (I have done that) and run auto program ( have done that).
all channels? outdoor antenna? if indoor antenna try moving antenna around to find the best spot, also you need to know from which direction your signal is coming from and how far you're from tv station, if too far you may need a signal booster, and make sure your antenna is for digital signals. same goes for outdoor antennas.
Jan 30, 2018 | Televison & Video
I need a good anntenna
Depends on how far away you are from the station. You may just need to elevate the one you have now. Just get a roof mount pole and mount the antenna on that. Radio Shack sells outdoor antennas especially for digital signals.
Dec 27, 2013 | Televison & Video
Will mounting sdv8622t/27 antenna higher improve reception.also if the booster stays dry is it ok to mount outdoors
Yours sincerely.
Elect_Comp.
May 24, 2011 | Philips Televison & Video
My Sony KDL-46V2500 can't receive digital channel of our outdoor antenna, the same antenna line that feeds to another TV that works fine, can someone help?
signal booster, different tuners require different signal powers, by splitting the feed you've effectively halved the signal strength, a booster should bring it back,
Apr 19, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have just got 22in plasma screen in bedroom but signals only 74% I have bought tv/fm 2 way signal booster will that help?
74% is good. If this is from an outdoor antenna and you are the only one connected to it no the booster will not help. The signal would need to be boosted at the antenna itself. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
Mitsubishi vs-50603 does'nt get regular antenna chanels.
Indoor antennas have very limited capabilities especially in areas with elevation changes and heavy tree cover. Ideally, you should put an outdoor antenna on your roof or the highest elevation you can find with a relatively short distance to the TV. Make sure it has a good UHF section as this is where all digital broadcasts will be sent by the broadcasters as the digital transition occurs. You might try an amplified indoor antenna for better results than what you have now, but its no substitute for an outdoor antenna.
michtech
Feb 16, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Is a booster needed for the tb100mw9 dtv converter box?
Best solution would be to use an outdoor antenna with an amplifier(booster)--but in some areas you may get by with an amplified set top antenna. Just all depends on your location..
In perspective, I have an outdoor UHF dish and 10 foot VHF antennas with an amplifier and still i get only fair reception on outlying digital stations that normally come in clear on analog.
Also--this converter box must complete the autoscan with an antenna attached, or else you'll receive NOTHING; not even by manually selecting a known digital channel.
This #@!! box automatically locks out what it considers to be unused or weak channels. It makes the decisions and you're left with 'no signal' messages and nothing to do but try a rescan.....and you cannot add channels to any it has already found.
Feb 02, 2009 | Insignia Digital-to-Analog Converter for...
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
