Question about Golf
A 2007 Club Car golf cart
Motor Generator shows 16 volts when running , Battery show only about 12.5 volts when running, I have replaced voltage regulator and is still the same. Gas golf cart
Posted by Lorette Thomas on
5 Related Answers
voodoomox
marlon john madrid
  • 1689 Answers
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Posted on Jul 24, 2008
weblord
William Nabaza
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
Anonymous
SOURCE: complete wiring diagram for a 1990 36volts club car golf cart
http://cartaholics.com/forum/index.php?showtopic=1880&hl=green+wire
See if this helps. Good luck!!
Posted on Jun 30, 2009
Anonymous
SOURCE: Need a schematic for a club car golf cart
new batteries-36 volts--can,t get power to motor------ help please
Posted on Dec 19, 2009
golfcartman
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
EZGO TXT, what is the voltage I should see at the battery while engine running under load?
Around 15 + or - a little. This indicates the alternator is charging.
Oct 18, 2017 | Cars & Trucks
My cart has 6 8volt batteries that are dead my manual shows 4 12 volt batteries should I replace the 6 8 volt with 4 12 volt batteries
make sure that they are in fact 8 volt batteries
You can replace them with 6 by 12 volt batteries as the end voltage (48 volts ) is the same
Mar 22, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
How do you check output voltage from generator to battery in an club car golf cart
if you look at the charger plug there is a small switch it can either be held down with the cover off or with it on. It should read you between 48 and 50 volts DC with that switch in that switch will keep you from charging the batteries if it is faulty. These chargers are really rather simple and golf cart King has the motherboards cheaper than anywhere else that you can buy them. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 31, 2014 | Golf
Troubleshooting charging system on a gas club car
Measure your battery voltage. Then measure your battery while cart engine is running. If you get 2 or 3 volts higher while engine running than when it's not, your charging system is ok. Lets say your voltmeter measures about the same voltage either way. Remove the small yellow wire on the starter/ generator and insulate. Place a jumper between the post that the yellow wire was on and the negative post of the battery. Now measure the battery while the engine is running. If you now measure higher voltage then your voltage regulator is bad, if you don't measure higher voltage then your starter/gen is bad.
Jan 25, 2012 | Golf
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 | Golf
Wiring diagram
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
Golf Logo
336 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
