Question about Vision Televison & Video
My pure vision media receiver stan bay lith red an green who is the problem
Posted by jorge luis lara on
2 Related Answers
Anonymous
  • 106 Answers
SOURCE: Red and Green double vision
Depending on the age of the unit. You have a convergence problem. This is not uncommon. You can contact a servicer thru this homepage and have them look at it. Convergence issues could be anywhere from 200-350 depending on your area.
Posted on Dec 17, 2008
Repair Ahjoshe
  • 885 Answers
SOURCE: hi both red and green
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Posted on Sep 13, 2010
Testimonial: "thank you verry helpfull"
I dont have a manual with my paramount night vision. how do you operate it. i can get a red light but thats all.
Hello, You should have two switches, one for on/off and the other for IR intensifier (red). There should be or not two LED one green to indicate on/off--no green LED it off, if the green LED glows green it on. The same with IR luminator, red is glowing the IR is on, if not glowing red, it off.
Make sure you have new batteries and make sure that the polaity is correct---positive +,
negative -.
Push the on button, if you push the right button the green LED will glow, then push IR button. Put you hand in front of the monocular and see if there is a red glow on the palm of you hand, if there is then the IR is on. Never look into the IR lens. Now you can look through the eye piece.
Now, if there no green tent inside of the monocular then there are other problems with you NV devise.
Never, and I mean NEVER look at bright light at night or in the daylight. This will destroy the image tube. That is one reason why they are call night vision....Only for viewing in the dark. stewbison
Aug 08, 2011 | Bushnell MOONLIGHT Night Vision -...
Trying to rewire a hampton bay light fan. I have
Try switching the red and white wires
But it should be working if the light is.
Make sure all the wires to the remote are connected good. You may just have defective remote.
Nov 29, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Connection
Hi...there,
Try Red, Green, Blue that is a sequence. settings all to 100% Have a nice day!
Feb 02, 2009 | iiyama Vision Master 404 Monitor
Dec 17, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
I have the Denon AVR-3805 receiver and I can't get it to turn on. When I press the "on" button, it turns from red to green but nothing else lights up. Can you help me?
By now the person who asked this (eleanorr) has certainly solved her problem, but in case anyone else has this same question:
It *is* on, as the color change on the Power button indicator light shows. Most likely, the receiver is fine; it's just that your front-panel display is off!
1. Check the DIMMER mode by pusing the buttom on the front panel -- it may be set to OFF.
2. Push the PURE DIRECT button on the front panel (or remote control) -- it may be ON, which turns off almost all of the front-panel display. (Alternately, change the AV source, which turns Pure Direct OFF.)
Jun 24, 2008 | Denon Audio Players & Recorders
Philips HDtv model 51pw9303/17f double vision red shadows
you need to replace both of the Convergence ICs STK392-120 you can get replacement ICs at the following link, and they provide free installation instructions and free on line tech support.
Heres the link.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | Televison & Video
Factory Refurbished Zen Vision Players
read this forum on the zen:
http://www.anythingbutipod.com/forum/forumdisplay.php?f=19
Dec 09, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision: m does not load past the Logo screen.
After you turn on the player, put your ear up to the back side of it and keep listening for about 2 minutes. If the hard drive eventually stops spinning or makes a repeated clicking noise over and over in a repeated pattern then the hard drive is bad. It sounds to me like that is the case. You will need to get the hard drive replaced. You should take it to a technician, or you can also do it yourself, but be careful. The parts inside are delicate and easy to damage.
Sep 05, 2007 | Creative Labs ZEN Vision:M Digital Media...
Wire harness
You can go to this site for all your car audio install needs http://www.tune-town.com/
Apr 20, 2006 | Kenwood KDC-4007
Televison & Video Logo
20 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
