Question about Golf
2005 DS 48v electric club car AQ05 will move for a second, after press pedal, and then stop. Does this in forward and reverse.
Checked battery cables and cleaned and tightened, does have a little corrosion on wires, inside cable lugs, but has 51 volts. Checked MCOR, checks 8 Kohms to 1.1 Kohms on three prong connector and open and closed on two prong connector.
Posted by Jay flowers on
5 Related Answers
Bruce Hathcock
  • 3600 Answers
SOURCE: I just changed my ford laser car 1988 model starter motor
plug the lug wire (Bullet connector into the starter (Bullet connector) from relay and you should be set. the square thing is the starter relay and wehn you turn the key to start mode it powers the relay that then starts the motor. this is a safety feature so the starter don't get stuck trying to start the car all the time. If you need help post to this replay and if helpful please rate this answer.
Posted on Sep 15, 2009
Testimonial: "Good Answer but problem still not solved . I have done exactly as you have mentioned still does not start. Is it the relay not working ? "
tberan1
  • 523 Answers
SOURCE: car wont start
Assuming power is getting to the starter fine I'd have to guess the starter is worn and may require replacement. I'd investigate the starter motor.
I hope this may have helped,
Tom
Posted on Oct 02, 2009
Anonymous
  • 254 Answers
SOURCE: My battery has been checked and is fine, but the
there is a power drain like a interior light check all lights incl trunk glovebox visors any thing connected to cigarette lighter close door sit in car see if there are any lights on if not connect a testlight remove ground batt cable connect testlight between cable and terminal if lights up there is a drain start to remove fuses one by one see if light goes out when a fuse is pulled look in owners manual see what circuits the fuse supplys can help to find problem try that need more help let me know
Posted on Jan 14, 2011
Anonymous
  • 123 Answers
SOURCE: The lights flicker and pulsate. All lights
you have a bad diod in your alt you can have this tested at auto zone they can test your diod on the car for free **** i know that is whats wrong
Posted on Jan 16, 2011
Samir3050
Samir Patheal
  • 70 Answers
SOURCE: gator wont go
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Posted on Mar 02, 2011
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Club Car cart will not move forward---works fine in reverse
check the forward/reverse switch. Possibly a loose wire. Unhook the battery and go to each wire and verify it is connected properly. Then reconnect the battery.
Aug 15, 2015 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Reverse circuit failed on Club Car 48v
Suspect you may be better listed in something besides Cars and Trucks, like Golfcarts.
Sep 17, 2012 | Cars & Trucks
Can I manually move the power adjustable pedals on my 2005 F150 King Ranch Crew Cab?
you can if motors are any good, the motors are reversable 12v only for a tempary fix.2 jumper wires and a 12v battery
Apr 15, 2012 | Ford F-150 Cars & Trucks
1998 48V electric club car - just replaced 48 volt batteries and two solenoids, but still can't get it to run. can hear back up alarm, but no juice to key switch or pedal. help!
If you go to www.studmonkeyracing.com/forums/cc48v.jpg you will find a schematic for what I believe will be close to wiring of your cart. A systematic check of volts to the various components should get you going. 1st port of call, you should see 48 volts on both sides of the keyswitch when it is on. Check the fuse in line with the red wire from the solenoid to the on-board computer.
It may simply be that you have one battery terminal too loose and it just wont allow you to draw enough current to run anything but the buzzer. Does the buzzer stop when you press your foot on the gas? If so it really does point to a loose battery connection.
Jun 10, 2011 | 3d Rose Londons Times Funny Cow Cartoons -...
I have an 08 Stealth 4 x 4 golf cart. On cold days it acts up almost like it only has half power. It's 48V. The batteries/ cables / output and drawdown tests were checked by a club car dealer and are...
wish there was an answer for this. One of the guys in our club has on with same symtoms. This past weekend it completley quit, so we had to tow it back to camp. Not sure what's wrong with it.
Jan 03, 2011 | Electronics - Others
2005 tuscon won't start turn the key there is silence the gear shift is locked up
Hi
Here is what you need to do.
Replacing The Stop Lamp Switch
Ignition off.
Remove the panel under the dashboard on the driver's side.
Removing The Stop Lamp Switch .
Press the stop (brake) lamp switch, from the side of the connector, completely forwards.
NOTE: A number of clicks should be heard and felt when pressing.
Disconnect the connector.
Press the brake pedal as far down as possible.
Pull the white bushing (1) as far forward as possible.
Press in the two locking lugs (2) on the reverse. Remove the stop lamp switch.
Thanks for contacting fixya.com
Oct 25, 2009 | Hyundai Tucson Cars & Trucks
Ez-go golf cart press accelerator pedal and nothing happens
The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
Aug 03, 2009 | Sport & Outdoor - Others
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 | Golf
Golf Logo
332 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
