Have a 70 yr old man that needs help
It should be one of these. It looks like 'R40A' might be the refrigerant gas in it.
https://www.google.com/search?q=Panasonic+%22R40A%22+inverter+air+conditioner+manual
A Manual that Google thinks is it.
https://docplayer.net/21544217-Operating-instructions.html
SOURCE: rewire air conditioner controls
Assuming "Window Unit" with rotary switch.
L1 (smooth part of line cord) to thermostat 1, thermostat 2 to overload (black disk) from overload to Common( C) terminal on compressor.
From Run (R) terminal on Compressor to Common (C) terminal on dual capacitor. From Start (S) terminal on Compressor to "Herm" terminal on capacitor. From fan motor to # 4 on switch = Medium Speed, to # 6 on switch = High Speed, from fan motor to # 7 on switch - Low Speed. Brown wire from fan motor to (F) on dual capacitor, white wire from fan to (C) on capacitor and L2 (ribbedwire) (N) to (C) on capacitor
SOURCE: looking for a panasonic r410a air conditioner
To change between heating / cooling / fan / dehumidify / auto, press the mode button. Each time you press it , it goes to the next mode.
SOURCE: I have a Panasonic split
I have a A C Panasonic, I m operate with remote bat not communicate, and than b emergency switch. indoor unit "on" but out door unit doesn't running. what wrong?
SOURCE: WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
SOURCE: Instruction Manual need for a
the compressor is not running and .near to the service unit their is a board and in it three leds ware their .when the out door is started that leds are blinking and compressor is stop and the fan is working for a at least 30 so what do u think the problem is.
