You asked 2 questions, really
1: what battery is bad, (the RTC coin cell is one battery that fails)
2: the main battery Lithium is bad.
one or both are bad, for sure on any PC this old.
the Q57 has a full model number that you skipped posting
matching parts for batteries , you need to tell that (the service tag tells you what you have) and unstated by you.
look here
there are no less than ,4 n the series Q5
https://support.hp.com/us-en/products/laptops/compaq-notebooks
q57-100 or 200, or 300, or 400?
let pretend you said, q57-100 (10 years old today)
then id say
are you in USA, and you say, yes, and.
go to fleabay and by the
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=cq57-100+battery&_sacat=0
no full model stated
no country stated, hard to help lacking that.
the RTC coin cell is here page 46
http://h10032.www1.hp.com/ctg/Manual/c01572022
the CQ57-200 uses the HP battery p/n
593553-001 at $72 plus tax plus ship at HP.
worth more that the PC used on ebay.
ebay has it for $13
those are examples with my guessing your service tag, numbers,
you can buy it too from walmart
if this is your battery; that is.https://www.walmart.com/ip/Replacement-B...
The battery is a 47wh, 6 cell,lithium ion battery
this is a battery pack made up of 6 separate batteries and what you have a indicates that one of those batteries is failing
you will need to get the new pack to fix the problem
go on line to Compaq web site spares to get a new one or search on e-bay-- battery for Compaq laptop make sure that you charger is charging before you order as well
compaq is hp. now.
there are 4 in the series.
hp sells parts at , partsurfer only
the cq57-200 battery is here, if you tell it the product number on the service tag correctly
here is me guessing.http://partsurfer.hp.com/Search.aspx?typ...
what is your LZxxxxx number ?
the tags look like
is located in the huge battery well on this compaq.
looks like this. not exactly like this but in same exact spot.
CQ77-XXXX WHAT IS XXXX?
AND THE ABA NUMBER. PRODUCT: XXXXXXXX
Telling the tag data, gets you correct parts
if not , not.
SOURCE: how to replace a compaq presario 1255 cmos battery
You have to take the case apart and find the old battery.It sounds like a large tast but you can pull it of in about 20 min.locate all the screws on the underside of the keyboard part of the laptop remove the main battery as ther may be a screw or 2 in the battery case once you are sure that you have removed all of the screws try seperating the 2 parts of the case sometimes they have clips that snap both parts together you can loosen then with a flathead if you find them by pressing inward and releasing them.once you have opened the case locate the battery and replace it .YOU CAN DO IT!
SOURCE: i bought a presario cq57-229wm. didn't have a user
You can get the manual on the link below.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=5111894
SOURCE: compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
SOURCE: I have a compaq presario CQ57 laptop and forgot my password
I have experienced the similar problem as yours. I forgot my HP Compaq Win 7 laptop password, finally got out of problem by DIY a password reset disk with Windows Password Recovery Tool 3.0. Your blank bootable USB Flash Drive will help you much now!
