Question about GE Freezers
I have a GE refrigerator, the motor evap fan went. part # WR60X10172. I put the new motor in,it worked. but when i mounted it in the back of freezer it shut off,
I can feel it vibrate. When i take the fan and point it toward the bottom of freezer it turns on, but, when i turn it upright it shuts off.
Posted by Mark Glose on
J Rosado
  • 1,201 Answers
Loose wire connection or motor defective
Posted on Aug 23, 2018
5 Related Answers
Anonymous
  • 237 Answers
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Posted on Nov 13, 2006
Anonymous
  • 1122 Answers
SOURCE: Hotpoint FAZ50 Frost Free Freezer
IF NOT THE THE DEFROST TIMER YOUR DEFROST HEATER OR DEFROST TERMINATOR IS BAD,REMOVE BACK PANEL INSIDE THE FREEZER YOU WILL SEE A LONG SINGLE OR DOULE POLE SHAFT THIS IS YOUR HEAT REMOVE BOTH LEADS ONE ON EACH END PUT YOUR VOLT METER ON OMES AND PUT ONE LEAD ON EACH END IF YOU GET ANY KIND OF READING YOUR HEATER IS STILL GOOD AND THE LITTLE ROUND CLIP ON TERMANATOR IS BAD, IF NO READING THE HEATER IT IS BAD,REPLACE-GET THE MODEL NUMBER INSIDE FREEZER AND GO TO LOCAL APPLIANCE PARTS STORE TO GET HEATER-REPLACE AND PUT BACK TOFETHER AND YOU SHOULD BE GOOD TO GO,ALSO MAKE SURE THE FREEZER FAN IS NOT STUCK AND TURNING,IF NOT TURNING SPIN IT WITH YOUR FINGER AND SEE IF YOU CAN GET IT GOING AGAIN,LET ME KNOW
Posted on Jun 15, 2008
Anonymous
  • 11 Answers
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Posted on Nov 28, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Posted on Feb 17, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
Ge gsl25jfta bs
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gsl25jftabs-repair/gsl25jftabs-frost-buildup.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 24, 2017 | GE Freezers
Need to replace evap motor for a whirlpool freezer
9abb6871-4eeb-4e17-b4b8-c4bfdafab542.jpgUnplug the refrigerator and remove the contents of the freezer. Then remove air tower and the inside back panel inside the back of the freezer. Disconnect the evaporator fan and replace with the new fan motor. W10189703 Evaporator Fan Motor I am here if you have questionsm Thanks Sea Breeze
Apr 20, 2013 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Kenmore Trio Elite Refrigerator (Model 596.76583601) Won't Cool, Freezer is Fine
the coil needs to be defrosted or the defrost timer is bad also go to sears.com and you can download a manual :) hope i helped a bit
Sep 01, 2012 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Evaporator motors won't run
Normally, freezers have electric heaters that are energized during the defrost cycle. Once out of the defrost cycle, the refrigeration system comes on but the fans do not. This allows the evap to cool off and to prevent circulating warm air from the heaters. This is controlled by a fan delay switch. It is a small, round device that can have 2, 3, or 4 wires going to it, depending on the manufacturer. It is usually clipped on to the end of the evap coil on one of the "U" bends, near the top, inside one of the ends of the evap. Usually where all the electrial components are located. It come in several variations, but it's main function is to prevent the fans from energizing too early. Usually does not bring fans on till evap hits 20 or so degrees. Check this out and get back to me.
Aug 13, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Evap fans not turning on
If this is a commercial unit, you're too low on refrigerant (freon). Freezer should be about a minus 10 degrees for the evap and high side is ambient converted to a psi for the type of refrigerant that is in the system plus 25-30 psi.
The evap fans will not come on because the evap is not cold enough.
Hope this helps and good luck.
Apr 09, 2009 | Freezers
Freezers Logo
424 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
