Question about Golf
Need bracket Upper on Push Cart to hold down golf bag.
Posted by john roessner on
5 Related Answers
weblord
William Nabaza
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
Anonymous
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Posted on Jan 22, 2009
Joe Hogan
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
Anonymous
  • 7 Answers
SOURCE: Taylor made driver repair
You should take it to the closest golf shop like a PGA superstore or Edwin Watts. If you live somewhere that doesnt have those resources then I would go to the local golf course next to you and ask the club pro where he would have his clubs repaired locally. Who knows, they may also do it right there at the course. It will run you a little money to replace the broken shaft, but the work and new grip will be less than $20.00. Good Luck, You may ask the person you were riding with if they pulled a prank on you with the bag falling off, Ive seen it happen. lol.
Posted on Aug 14, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: need a manual for my
You can download and print the instruction manual for Yamaha G16A golf cart in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Your feedback is important to us!
Kindly rate and accept the solution if it helps you.
Posted on Jul 29, 2011
What is the right air pressure for sun mountain golf cart
8.What is the recommended tire pressure for the Speed Cart pneumatic tires?
The recommended tire pressure is 30 psi.
FAQ ' Customer Care - Sun Mountain
https://shop.sunmountain.com/faq.html
You may also purchase products directly from any of the preferred internet retailers or shop.sunmountain.com. ... If the tire pressure checks out and you have a cart outfitted with bungee cords or strapless bag bag bracket you can adjust the alignment by following the instructions in your user's guide. If you have an older cart ...
[PDF]Speed Cart® SVl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/SV1_UserGuide.pdf are perfect for balls, tees, snacks and keys. • Mesh headcover tray. accessories include the. Speed Paq and. Umbrella. • Ergonomically designed to push without straining your shoulders or back. • Large diameter f tires are maintenance free. I. • The E-Z Latch System / makes folding and unfolding the cart simple.
[PDF]Speed Cart® V2 User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V2SpeedCartUserGuide.pdf Speed Cart® V2. User's Guide. To take full advantage of the ergonomic features of your new Sun Mountain. Speed Cart, please read the following information. ... on the side of the brackets, place your golf bag on the cart and retighten the thumb ... your manual brake is not holding, first check the tire pressure on the front.
[PDF]Speed Cart Vl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V1SpeedCartUserGuide.pdf *Reverse these steps to fold and store your Speed Cart. STEP FOUR: STEERING. To steer your Speed Cart push down on the handle so the front wheel lifts slightly off the ground. Then pivot tight or left to change direction, lower the front wheel and go. When adjusting the handle or folding the cart, please note that the tires.
sun mountain golf cart tire pressure Google Search
Mar 12, 2018 | Golf
Where are the clips at to take body off a golf cart. Yamaha gas, trying to put seats.back on
Lots of stuff here. Remove the drain tubes then remove the bag rack, seatback, and bottom of top supports. Remove the two 10 mm bolts in the bagwell.
Remove the seat bottom brackets from the body and the two pushpins.
Now you have to remove two pushpins on each side, one is under the side panel and the other is in engine compartment. These pushpins are at the rear of the side panels. Should lift up off the cart.
Apr 11, 2017 | Golf
What button to I press to fold the handle of the cart into the body.
Took me awhile to figure this out too. Very simple: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Mar 09, 2014 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
How do I align the front wheel of the Bag Boy DLX push cart?
Unfortunately, there is no adjustment on the wheels of the DLX. However, you can often adjust it's alignment by ensuring that the weight of the golf bag is properly centered on the cart.
Aug 17, 2013 | Bag Boy Bagboy Express DLX Push Carts
I can't fold my caddytek lite 11.5 v2 cart
I'm sure you figured this out by now, but for others stuck with the same question, here's how you fold it: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Jan 21, 2013 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
I NEED A NEW LATCH HOOK BRACKET FOR SUNMOUNTAIN GOLF CART
Hi try here
https://www.sunmountaingolf.co.uk/article.php?xArt=25
Oct 20, 2012 | Sun Mountain Speed Cart V1
Golf Logo
302 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
