Radio Communications Logo
Question about Radio Communications
Why does my billboard Bluetooth device beep when I'm listening to music?
Posted by Pamela Loomis on
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: listen to music
You defently can. I do with my moto q and my h700
Posted on Feb 15, 2008
Anonymous
SOURCE: Can I listen to my music player on a Bluetooth earpiece?
You have to register your bluetooth device with your dash. Choose Start > Comm Manager > Bluetooth. Make sure it's enabled. Then choose Settings (right soft key) > Bluetooth > Bluetooth. This should show you Add A new Device. Turn your device on and set it to register, then select Add a new device and follow the directions.
Posted on Oct 07, 2008
Anonymous
  • 34 Answers
SOURCE: i cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Posted on Mar 10, 2009
Anonymous
SOURCE: LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
Posted on Oct 20, 2009
Anonymous
  • 4 Answers
SOURCE: I can't listen music through my bluetooth headset with iPhone
My Jabra Halo works to play iPhone's iPod music as well as phone calls. So does Jabra Arrow, I'm told. The bluetooth must have A2DP.
Posted on Jan 10, 2010
Motorola h15 bluetooth listen to music on android phone
This headset only allows for handfree profiles. You need a bluetooth stereo profile or A2DP profile. I'm afraid you can't listen to music using this device.
tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 • Cell Phones
Cant listen to music on my 975
The Plantronics Discovery 975 Bluetooth headset does not supports Advanced Audio Distribution (A2DP) and you need this Bluetooth profile to be able to stream music between two Bluetooth devices. The device you are streaming music from (example: cell phone) to the headset must also support Advanced Audio Distribution (A2DP).
Good luck from Headsets Direct!
Cant listen to music on my motorola i1 & plantronics explorer 233
Plantronics Explorer 233 Bluetooth headset does not support the Bluetooth profile Advanced Audio Distribution (A2DP). Your Bluetooth device and your phone both need to support A2DP profile, without this Bluetooth profile your devices are not capable of streaming music.
Hi can I listen to music thankyou
Plantronics Explorer 240 does not support the Bluetooth profile Advanced Audio Distribution (A2DP). Your Bluetooth device and your phone both need to support A2DP, without this Bluetooth profile your devices are not capable of streaming music.
5helpful
2answers
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
3answers
Want to know how I can listen to my music through my bluetooth
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
Jan 17, 2011 • Cell Phones
3helpful
2answers
I cant listen to music connecting my bluetooth
or
2answers
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
