Question about Maytag Refrigerators
I have a maytag model MFI2568AES. Lights are flashing and the ice compartment door is opening and closing.
Posted by Allen Maxey on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
Anonymous
  • 145 Answers
SOURCE: Maytag Mod # MFI2568AEB..SER 10962398JC....Problem....all
The capacitors on the high voltage board on the back are out. You will have to replace the board.
Posted on Apr 23, 2008
Anonymous
  • 113 Answers
SOURCE: our frig ice cube door
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Posted on Oct 24, 2010
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: Replaced HV board on Maytag MFI2568AES fridge.
increase the thermostat settings to a more cooler temperature
Posted on Dec 28, 2010
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: Maytag MFI2568AES Ice maker is
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 12, 2011
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
What does it mean when all the lights are flashing on the control center and the ice dispenser door keeps continuously opening and closing?
you have a big problem . they call it the jazz board . the main control will have to be replaced . this is only correcto to the problem .. mm
Aug 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
217 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
