Question about JVC Audio Players & Recorders
Hooked up my old JVC AL A158turntable to my RX-V371 receiver. The audio sounds very tinny and I have to crank up the volume. Any reasons why? Thanks
Posted by Paul Mangiameli on
5 Related Answers
Anonymous
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
Anonymous
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
ABRsvcs
  • 4234 Answers
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Posted on Apr 12, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Yamaha Receiver RX-V463
Do not use HDMI thru your receiver. Go directly from the Cable box to the TV. Connect coaxial digital or optical to your receiver. Your receiver uses HDMI version 1.1 or 1.2, which is riddled with issues. If you want to read about them, Google HDMI Problems and you can read for hours. Long of the short of it is; Don't pass HDMI thru your receiver, use the receiver for audio only. Hope this answers the question. Sorry for the bad news! I'm in the industry and have been dealing with these issues for a couple years now.
Posted on Dec 16, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have an RX-V663 audio sounds flat
Let's deal with the turntable sound first - unless it's a self-preamplified model you would have to get an external phono-specific preamp to use with this receiver. Without one you'll get microscopically weak, tinny sound from the turntable. Google "RIAA curve" to see why.
As far as the CD sound through the Blu Ray player... for one thing it is flat, as in two-dimensional stereo. Compared to genuine surround from a movie it would be a letdown.
Can you better define 'flat'?
Posted on Feb 04, 2010
Testimonial: "Thanks for working on this with me, you really dove in!"
HAVE A YAMAHA RX-V371 RECEIVER, NO CABLE BOX AND I CANT GET ANY SOUND FROM MY PHILLIPS HDTV.
if you have a coax digital out on your tv, why not use that, you have coax, optical, and hdmi inputs on your reciever, but the easiest, low cost way is the coax
Feb 20, 2013 | Yamaha RX-V371 A/V Receiver
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Feb 04, 2010 | Yamaha RX-V663 Receiver
Sound not coming through speakers correctly
Check that the speaker setting on the receiver is set to large not small. (if you have 6inch or larger woofers)
If you have only small speakers you will need a subwoofer.
Feb 22, 2009 | Yamaha RX-V363 Receiver
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
Jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Dec 21, 2007 | JVC RX-6000V Receiver
56 people viewed this question
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
