SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
SOURCE: Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
SOURCE: not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
SOURCE: samsung ml-1640 giving red light, not taking papers
I had the same problem when a paper jammed and I have pulled it out. The red light came on and nothing worked. My solution was: I pulled out the tonner and put it back, opened all covers and closed it. All this apparently must be done with printed turned on (the same thing with printer turned off didn't work). Hope this helps.
Mindaugas
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
