Question about Golf
Cart says it’s charged but won’t go far - Golf
Posted by Gloria Wallace on
Tom Chichester
    Top Expert:
  • 56,046 Answers
  • Defective battery
  • Defective charger
Posted on Jul 08, 2018
I have a 2010 yamaha golf cart,has brand new batteries,and the batteries drain by nine holes,is it the voltage regulator? or something else
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
Nov 05, 2017 | Golf
Myezgo 2007 golf cart wont charge thr batterys bill has the same cart his charger wont ework either
Check your batteries under load, then check the wiring. Make sure the black and white charging wires are connected to the mains. If all good then check the pins in the charging receptacle.
May 31, 2017 | Golf
If cart goes dead how long will it take to charge to get it back on the trailer?
Usually a cart takes 8-10 hours to fully charge. But in your case to get it to load on a trailer 3-4 hours should do it. Warning: DO NOT TRY EARLIER THAN 3 HOURS !!! IT WON'T MOVE FAR EVEN IF IT STARTS MOVING GOOD.
May 10, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
When I completely charge my golf cart the charge meter no longer goes all the way to the top. Are the batteries close to having to be replaced? Or could it be some less expensive problem?
hi will the life spam of the battery is only for 2 years if that is more than 2 years your lucky to go further the life of your battery..maybe in the series of the battery on your cart there is 1 that weak already.
Sep 14, 2015 | Golf
How long will a Schwinn electric scooter hold a charge?
Hi, if you use this link you will be able to find what you need to know,
http://cart.electricscooterparts.com/v/searchresult.asp?sw=how+far+will+one+charge+take+me
Sep 14, 2014 | Motorcycles
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
Golf Logo
433 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
