Question about Firearms
Bought a Gamo Wildcat Whisper and it does not fire. Brand new, there is no lever to pump so assume it uses a CO cartridge but don't see where to change it. No owners manual in box
Posted by Cheryl Slaughter on
ray gallant
    Top Expert:
  • 69,278 Answers
It is a break barrel rifle not co2 or pump up .
Posted on Jul 08, 2018
5 Related Answers
don_farr
Don Farrell
  • 1018 Answers
SOURCE: Black 32 cartridge not working in X5410 printer
Did you purchase a "Lexmark" factory new cartridge or was it a third party cartridge made for a Lexmark printer.
The Black 32 Cartridge is listed for the family of printers. So either you have a defective cartridge (Contact Lexmark and ask for a warranty exchange of the cartridge) or return the cartridge to the store you bought it from and tell them your problem.
Posted on Jul 13, 2009
Gilbert Gonzalez
  • 239 Answers
SOURCE: J1 Error, Changed a brand new factory-sealed toner, still getting J1 Error
Make sure you have the right code: J1 or J2.
one is for the drum and the other is for the ink.
Make sure the toner unit is for this model and not for a different model.
If the old modual is still available, check the connectors at the back and see if they are the same.
If anything else Call Xerox for repair. If the cartridge was bought through Xerox have your reciete available for warrenty.
If repairs still need to be made, A Xerox service call may be needed in order to fully repair the copier and warrenty the cartridge.
Posted on Oct 23, 2009
Jim Dandy
SOURCE: need an owners manual for a RIDGID radial arm saw RS1000
http://www.ereplacementparts.com/images/ridgid/RS10000.pdf
Posted on Nov 30, 2011
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
    The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
    1. Make sure the printer is on.
    2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
    3. Remove both cartridges from the carrier.
    4. Close the printer cover.
    5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
    6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
    7. If no error appears, reinsert the other cartridge. Close the printer cover.
    8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
    Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
    Posted on Feb 15, 2012
    suziejones
    • 13 Answers
    SOURCE: What equipment do you need to use your diaper changing table? I bought a brand new changing table for my new baby but feel like I don't know what to do with it.
    Don't worry, there's no right way to use a changing table. The important thing is to make sure you have all the right stuff with you before you start changing your baby's diaper as you can't leave them unattended half way through to go and get something. Check out this YouTube video that gives a detailed but easy to follow guide to changing tables.
    Posted on Aug 14, 2012
    My Remington mod. 7400 rifle will eject unfired sells from the magazine but when rifle is fired the bolt moves all the way back, but spent cartridge stays completely in the magazine. how get pts?
    Is it possible that your ejector does not have enough tension or material to grab the spent casing to pull out? The casing expands in the chamber after it is fired and will be difficult for the ejector to dispense the empty casing if it is not able to get under rim. Try this out first and see where it leads you. Cheers and good shooting!
    Oct 27, 2018 | Firearms
    What are the best pellets to use for the Gamo 776. Not all .177 pellets fit when loading. Thank you for your time
    Depends what your target is. I favoured Prometheus, steel head and plastic skirt. For plinking anything in a tin will do.
    gamo 776 best ammo Google Search
    Oct 07, 2018 | Firearms
    The last bullet in the tube of my model 60 marlin won't slide in to load. all other bullets other than the last one load and fire. the last bullet can be hand loaded and will fire
    Could need a new spring in the magazine tube.
    Ebay has complete inner magazine tubes.
    search for Marlin Model 60 .22 Inner Magazine Tube
    Aug 20, 2018 | Firearms
    A manual for a Gamo air rifle 04-1C607111-06
    Google (gamo)(04-1C607111-06)(manual) without parens.
    Aug 15, 2018 | Firearms
    Load data for 8x57mm Mauser with 170gr hornady sst bullet
    Go to http://www.hodgdonreloading.com/
    Select 8x57 mauser as the cartridge, then select 170 as bullet weight. Select the brand of powder and read the results.
    Aug 01, 2018 | Firearms
    Hi bought a daystate renegade fired about 600 pellets in 177 now will not fire any ideas why
    All air guns need gun oil down the hole the air comes from in order to keep plungers from wearing out . Treat them every few times out with a small drop or two. Also check to see if you had a bad pellet get stuck.
    Apr 05, 2018 | Firearms
    How do i remove stuck pellets in the barrel of my gamo c 15
    Hello, William -
    According to the instruction manual for the Gamo C-15 Blowback firearm, you could use ". . . a 4.5mm caliber cleaning rod (.177 in) if a BB has become blocked in the barrel."
    The information regarding a blocked barrel is on Page 11 of the instruction manual in the REPAIRS section.
    If you do not have the instruction manual, this is the link to the PDF document (Adobe Reader software needed - free):
    TinyURL link:
    https://tinyurl.com/y9zwcvtk
    The information is on Image 6, right side, of the PDF document.
    (Quote from the instruction manual):
    Repairs
    A compressed air p1st0l (have to spell it that way or the Fixya algorithm reads it as a "bad word") that is not functioning well can be dangerous. Do not attempt to repair the gun yourself, since this may cause abnormalities in its functioning. Use a 4.5mm caliber cleaning rod (.177 in) if a BB has become blocked in the barrel. Take your gun to approved gunsmiths or to professional repair specialists approved for this type of product.
    (End quote)
    Best wishes.
    Feb 22, 2018 | Firearms
    How do you determine weather a 700 is long or short action
    there are three lengths of action (not including the Model Seven's lightweight action, which is even shorter than the 'standard' short action). There is the short action for cartridges up to 2.800 in (71.12 mm) in overall length like the .308 Winchester cartridge family, the standard action for cartridges up to 3.340 in (84.84 mm) in overall length like the .30-06 Springfield and .300 Winchester Magnum cartridge families and the long action for magnum calibers exceeding 3.340 in (84.84 mm) in overall length like the .300 Remington Ultra Magnum and .375 Holland & Holland cartridge families.
    Extract from Wikipedia article
    Mar 06, 2017 | Firearms
    Firearms Logo
    194 people viewed this question
    Top Firearms Experts
    Marvin
    Marvin
    John Donghia Jr.
    John Donghia Jr.
    jws1013
    Are you a Firearm Expert? Answer questions, earn points and help others
