Question about The Computers & Internet
How to a check how much space I have left on the internal hardrive?
Posted by Carolyn Mitchell on
Bill Boyd
    Top Expert:
  • The Master
  • 53,814 Answers
On the programs are after you click on the microsoft icon in the bottom lh corner , click on computer and then use the tabs to get the pie chart for space of the hard drive or the remaining space
Posted on Jul 07, 2018
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Jun 16, 2017 | Seagate Computers & Internet
I own an 80GB PS3 currently. I've been tight on hard disk space so I decided to purchase a 500GB Hitachi internal hardrive. I re-installed the new firmware updates along with trophies, PSN games, and...
I think its better you check your re-installed updates,games etc......Try removing some unwanted files and increase the disk space.....also this problem arise when your newly installed drive is not compatible with your software.....
Thank You friend hope it helped you solve the problem sorry if it hadnt....
Jun 24, 2011 | Sony Gran Turismo 5 for PlayStation 3
When I attach the transfer cable to the 120GB hardrive it only shows it as a usb drive with 16GB of space. I checked the hardrive on my computer and it shows 120GB of space, how do I get it to show as a...
16 GB is the maximum USB storage the XBox will allow, but you may have up to two devices connected at the same time (which means nothing for your current situation, sorry). This is Microsoft's way of saying you should've opted for the larger internal hard drive.
Jan 01, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
My computer says I have not enough memory.. I have 4 Gig of RAM and 200 Gig left on my hardrive space...when I use sound recorder it really cracks it. I have tried everything from the system menu to...
ok go and check your c: drive memory status if you found less memory their then that will be the problem it is not only the case of a c: drive check all the drives how much space is left if not so space is there partion again and left a space of about 30 gb for c drive the place you installing the operting system and remaing can be used according to your taste and also try to install application in remaing drives dont try to install the whole applications in the c; drive it will slow down and shows low disk space and in every 3 days do this procedure just right click on the each drive take the properties and just click on disk clean up button it will help to remove all the unwanted programmes from the disk and this procedure will not allow your system to run out of memory try this thats all.... thanx for asking...
Oct 18, 2009 | Computers & Internet
When ripping from music cds the coputers hardrive switches off
How much empty space do have on your C drive? Shift all storable media in the other partions keeping C drive as empty as possible. When the buffer memory finishes it has a resrved portion of the HDD for this purpose. If that space is not left on the C drive then it will shut down if left on its own. Like the ripping job. Defragment your HDD for better performance.............sodeep
Jul 31, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Need to clean up space on hardrive
you need to delete the songs, videos and pictures those are the type of files that make space. but before you do that makesure they're backed elsewhere if you need them.
Mar 03, 2009 | HP Pavilion a350n PC Desktop
How to find out how much space is left on my Seagate ext Hardrive
While your external drive is connected to your computer and its already recognize by the computer , Just double click Mycomputer icon and right click your external hard drive and select properties and ther you can see how much free space you still have...
Don't forget to rate the solution FIXYA thank you...............
Oct 20, 2008 | Computers & Internet
Can't access internal hard drive
check if hardrive is dammaged or connected right if not get a new hardrive or if you have xbox live recover gamertag. good luck man or lady! lol
Oct 18, 2008 | Microsoft Xbox 360 Console
7210gx won't power on.
You know what its probably that the power button is not connected to the motherboard. Pull the power button piece back out and reconnect the cable on both sides.
If that doesnt do it, the plastic power button itself might be broken. You can replace that whole button board to fix it. usually $60-$80 for the part (gateway does not sell parts so the companies that do are expensive)
But check that cable first and let us know if it works.
Dec 17, 2007 | Gateway 7210GX Notebook
Computers & Internet Logo
59 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
