Step 1
Locate the "Clock" button on the display. The display is located above the oven door. It clearly shows the time and has settings for temperature, time and cooking.
Step 2
Press and hold the "Clock" button until the time starts to blink.
Step 3
Set the time with the number pad. Ignore the colons and enter the number straight through. For example, if the current time is 10:08, just type 1-0-0-8.
Step 4
Set AM and PM by pressing the "#" button. Press "Start" to finish.
Hi there, thank you for your answer. However, our oven is at least 5-8 years old and does not have the number pad.
With a model # someone can find the answer at a manuals.com website
use a search engine put in ERD48SCH/NG oven/range manual [your model number]
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
SOURCE: Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
SOURCE: Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
SOURCE: clock is in Military time...can't change it back...
If you call Dacor they will talk you through the solution but you have to have another person ready to turn the breaker off while someone is pushing a button. I have contacted them and am trying to get the instructions emailed.
Dacor Toll free: 800-793-0093 have model # ready
SOURCE: I have a blue hat toy co. time and space
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
