Radio Communications Logo
Question about Radio Communications
I have a cobra19 ultra 3 and I replace the mike but I still can't transmitted out what do I do
Posted by Jack Wolfe jr on
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: 2001 Ultra CB radio does not transmit
hi the radio internall will have a driver and final transistor these are for the output signal or tx. you might find that the final transistor is faulty and needs replacing these fail due to incorrect swr or tuning of the antenna or cable / connector shorts. dont over look a bad microphone connection wiring on either end and internally on the ptt switch
most common driver is 2sc2166 and 2sc1969 for 27mhz amm & ssb
Posted on Jul 22, 2009
1helpful
Gme gx300 transmitting problem
do you have a mike filter on your system
Jul 19, 2013 • Boating
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
On a cobra mike what color wires are transmit,receive, auto ,common
Hi, my name is John. Welcome to FixYa. # 1 is the shield, # 2 is audio- white, #3 is the transmit- red, #4 is the receive- black. Good luck and thanks for choosing FixYa...John
I want to know how to tune my cobra 19 3 ultra cb so that i can recieve and transmit
you can't tune the radio. You must tune the antenna. I have a generic thread which explains everything you need to know about tuning your antenna.
See here. Hope this helps you.
COBRA 21 GTL NO MODULATION NO RX. BUT IT WILL TX AT 3 WHATTS.I HAVE TRIED 3 DIFFERENT.MIC ON THIS RADIO CAN YOU HELP ME
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Key mike no hears me but shows meter
You didn't mention if you hear the other radio. If not, here's a common problem and solution.
However, if you hear them, and they see your signal, but no talk (modulation), then the problem is usually your mike. Try another one in this case. Thanks, Bill
2answers
Radio will "receive" but not "transmit". Radio, antennas, and wiring are all less than two years old. Should I try a new mike?
Firts you have to check for carrier.For this you need an swr meter.2) Check continuity between the pl259 tip and antenna.3) Check for modulation (voice) if all of the above are OK. 4) Check if your display changes to transmit when you press the mike. IF all fails,then try another mike.
1helpful
2001 Ultra CB radio does not transmit. It receives fine. When you key the mike, the CB radio display (squelch) goes blank, headset sidetone is very weak.
1helpful
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
