Question about Johnson Boating
What is the oil/gas mixture for a 1994 25hp Johnson outboard motor
NOEL
    Top Expert:
  • 8,549 Answers
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
Anonymous
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
Editor925
Dean
  • 285 Answers
SOURCE: oil mixture for a 70 hp Johnson boat motor?
If it is a 2-stroke motor than gas:oil ratio should be 50:1
Posted on Sep 04, 2009
thomasnee
  • 677 Answers
SOURCE: i have a johnson outboard motor that drips oil
Yes the prop shaft seal needs to be replaced.Do this sooner than later as water will get into the lower g/box.Sometimes they wear out or fishing line is a bad culprit.Its not a big job but it really needs to be done.The oil will also need replacing.Hope this helps
Posted on Sep 09, 2009
Anonymous
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
Posted on Oct 20, 2009
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
What is boat outboard motor oil to gas mixture ratio?
All the motors I have used required a 40 to 1 gas to oil mixture.
Aug 16, 2014 | Light Outboard Motor Boat Bass Fishing...
What is the gas/oil mix for an 80 hp johnson outboard motor
Even thought there are many expert tech's with sometimes more years of experience on this site than some you may find working in a repair shop, and of course many that simply give you their guess as the correct answer. I would recommend calling a Johnson Outboard Dealer or an outboard repair shop.
Jun 12, 2013 | Boating
What is the gas mixture for a 9R-70C?
What a neat little fisher motor. All needle bearing motor so you can run it on 50/1 --would use synthetic for the best operation. Take care of that starter spool- slowly engage the plastic gear to the flywheel before you pull the starter for the start.
Aug 06, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Do i need to mix fuel for a 1988 15hp johnson outboard motor J15RCCS?
Yes.Fuel mix is needed.Mixture is 50/1 fuel /oil. Eg.50 litres of fuel/1 litre of oil.Oil bottles you buy have measurements on the side of them.Hope this helps
Aug 29, 2009 | Boating
Boating Logo
647 people viewed this question
Top Johnson Boating Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
