You cant find the reset because there is not one. OKI do not use resets to cure errors. Yes a 980 is paper wrapped around the hot or pressure rollers in the fuser. Normally you just take out the fuser and remove the paper and it will start working. However this MUST be done with the power OFF. So it should be a case of just turning it off and removing the jam and refitting the fuser and turning it back on. If the error is still there then alas a new fuser is require to get it going again. You may be able to buy a fuse from suppliers on the net, fit it and that will do the reset without the need of buying a fuser.
SOURCE: Oki C6100 Laser Printer drum reset - from Fatal
The instructions below do not apply to my okidata c6100. It does not go to "NV-Ram initial" , after you get to " Engine Dialog Mode" , even if you scroll down.
I bilieve that the okidata c6100 has a different way to reset the drum units.
Anybody can help,
Thanks
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
SOURCE: How do I reset fatal
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
