Question about Golf
How to find the timing marks on a robin engine eh35 c
Posted by Tom Dack on
I need a new robin subaru thottle body r1100
I believe this generator uses a carburetor.
Try calling Jack's Small Engines during their business hours; I don't see a carburetor listed separately and it may be very expensive.
Robin Subaru R1100 Generator Parts Diagrams
You may be able to just clean the carburetor you have and save a lot. The video isn't the exact engine but it is close.
Feb 08, 2015 | Subaru Cars & Trucks
I have a homelite LR4300 with the 7.5 HP Subaru engine. The governor is not working. Whats the poblem?
Unclear when stated that there is a governor issue? I assume you have a Robin/Subaru 7.5 H.P. engine model EY280YD2510 with erratic behavior leading up to stalling out when a load is applied or the generator is at no load status after several minutes of run time?. Couple of things to check would be starting with the fuel system. Is there stale gas in the fuel tank? Have you verified fuel flow from tank? Is the fuel cutoff valve free of debris? Is the carb fuel bowel been removed and inspected for varnish? Is the air cleaner clean? Next, Ignition system. Have you inspected the flywheel for excessive rust? Have you reset the air gap on the ignition module? Does the on/off switch work (measured with a meter for continuity?) Any visual signs of damage with all wiring or the ignition module itself? I once thought I had an governor issue where the issue ended up being that the flywheel was corroded to the point that once the engine was fully warmed up the control module would contact the rust build up on the flywheel causing engine surges no matter what the load was on the generator, and at times would stall the engine. Clean flywheel off if necessary and reset the air gap on the ignition module. If that fails then inspect the governor spring (the top spring on the carb. linkage assembly) for excessive rust that will change the tension on the governor arm.Replace if in doubt! When doing all this inspecting ensure you have fresh fuel, oil, air filter, spark plug gapped correctly, and ignition module that has been tested as sound! These Robin engines are smooth running heavy duty engine that will perform for many years if taken care of. Good luck!
Dec 07, 2013 | Robin Subaru Electrical Supplies
Exchange robins 265cc in place of robins 350cc in e-z go utility vehicle
Yes, you may have to make or modify some brackets to make it fit, but if it was too easy it wouldn't be worth doing. First you will need to get hold of a wiring diagram of both engines.
May 17, 2013 | Motorcycles
My Powermate Generator, model 5000 , with Subaru Robin Engine is taking so much oil. I called somebody to service/repair it and he discovered that it has a Timing System. I dont have the Timing Settings...
First of all i can't see the timing having anything to do with your using too much oil. The timing will only affect the starting and smooth running of the unit. However, if he has to take it apart then in order to fix the timing he needs to set the coil gap to around 11 thousand of an inch. Also, if that doesn't work and he still insists it's the timing then youll have to remove the engine from the generator and split it apart and realign the marks on the cam shaft with the marks on the crank. Again, i can't see that being your problem but i'm just saying. Sounds like to me its either the valve guides are worn or the piston rings are worn out or worst yet a scar on your cylinder.
Oct 20, 2017 | Electrical Supplies
What is the code for round robin in visual basic 6.0
That's not a question easily answered in the sense of a "language" (like VB, C or otherwise).
Round-Robin is actually a term for sharing a "time-slice"...
Meaning.. lets say there are 3 parties... each want 70% utilization of the processor (or time)... But.. obviously... 100% is all you have.
So.. How do you "fairly" share the time? There's a couple of ways, round-robin (for interrupts for example on x86 based processors) is a method.
What it means is-- regardless of how much time you want, or need.. the kernel (Operating system) will give you so long to get "whatever you are doing"...Done.
If you don't get it done in time... the next guy gets to do his job..for a similar amount of time... and the next guy.. and then..say-- back to you.
Hence..Round-Robin.. we all get a slice, and if we don't get it done in-time... next time around we'll another slice to get more work done... maybe the other 1 or 2 or N guys... are done, and we'll get move time..maybe others have joined in, and we'll get less-- its to-be-determinned at run-time...
That's not a code answer... I know.. but the question was a little abstract, if you can be more specific (code wise), I may be able to give more of an example..but for now, explaining WHAT it is may be more useful.
Oct 19, 2012 | Microsoft Visual Basic 6.0 (361-00686) for...
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
How to read timing marks on robin reliant L-REG
YOU WILL NOT USE A TIMING LGIHT ON THIS CAR
Mar 22, 2009 | 1986 Plymouth Reliant 4 Door
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
Golf Logo
486 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
