Radio Communications Logo
Question about Radio Communications
Motoroloa N136 Bluetooth headset blinking red & Not syncing
I have received a headset from a family member and have been charging it all night, the red light is still blinking. I also cannot get it to sync to my phone.
Posted by Sam Melo on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Sync the headset
You never said what model is your phone but the general practise is to pair the headset to the phone.how?? Make sure the headset is fully charged ,normally showing blue light depending on the brand. 1>While the phone is on ,press a button on the headset and it(headset)should show a blue light depending on the brand. 2>keep this button pressed and go to your phone's bluetooth configs and select a 'add audio divice' tab.The phone will search for for any headset in the vicinity till it finds yours. 3>Select your headset name shown on the phone and you could be required to enter password to pair,in this case most will be (0000)or (1234). Sorry had to be this long!!!!
Posted on Apr 24, 2007
Anonymous
SOURCE: forgot how to sync my
Hold the up volume and the talk button (the one on the side of the ear piece) down until the status light flashes red then blue.  This places the headsead into pairing mode.
Posted on Jan 06, 2009
Anonymous
SOURCE: Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Posted on Feb 12, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: how do i sync motorola h710 bluetooth headset to my cell phone
here is the procedure kindly rate me well !
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/H710/US-EN/_Documents/Static%20Files/H710_QSG.pdf
Posted on May 03, 2009
Anonymous
SOURCE: i just bought the hfblu-10k
I was given this bluetooth after a buddy of mine could'nt figure it out. I figured out how to sync it by following that longer than 5 secs. idea that's posted here. I did'nt have a manual so I just put in "0000" and it worked! So try that...Good Luck. Thanx4Hating
Posted on Jun 02, 2009
1helpful
I found a motorola bluetooth n136. Will it work with my iphone?
Yes it will. Here are the instructions for pairing it.
How to Pair a Motorola N136 Bluetooth Headset ' Techwalla
www.techwalla.com > ... > Entertainment
The Motorola N136 headset, which has been updated as the nearly identical HS850, gives cell and smartphone users wireless hands-free usage with Bluetooth ...
2answers
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? [email protected]
4helpful
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
5helpful
I have a Motorola N136 hands-free ear piece and cannot get it to sync with my Blackberry. I need some help.
It's not actually an N136. It's an HS850.
To pair it, turn bluetooth on the blackberry on.
Close the mic on the headset.
Hold down the headset button until it lights up.
Open the mic on the headset.
Tell the blackberry to search for devices.
You should be back in business.
Jun 17, 2008 • Cell Phones
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
