SOURCE: Whirlpool Gold GU15 dishwasher won't start
The appliance repair technician just diagnosed the problem for me. He says it's a bad touchpad, and it would cost $257 for him to replace it. Thought I'd share the diagnosis in case anyone else comes upon this thread.
SOURCE: My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
SOURCE: whirlpool gold dishwasher is NOT
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
SOURCE: My Whirlpool Gold,quiet partner 3,model
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. Now if youheard the HUM then it canbe that the motor is not initiated which is relative to a faulty pump or motor. Also the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor . Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water . Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump. Please check the link below: http://www.espares.co.uk/advice/dishwashers/a/3 For spares click On: http://www.espares.co.uk/search/dishwashers/p/1083
