Question about Golf
I have a parmaker spirit golf cart. What voltage does it run on and how many amp hours. Is it connected in parallel or series? Regards Mario
Posted by Mario Barravecchio on
5 Related Answers
uge44
Eugene Tetlow
  • 226 Answers
SOURCE: 500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Posted on Nov 19, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: trying to power a amp with 16 volts. possible?
Golf carts do not have a charging system. If you are going to use battery power only, why not just add (1) 12V car battery instead of (2) 8V??
MA Audio runs (ran) their bench tests @ 17V. All the power ratings advertized are at 17V.
The power supply for the hk4000D is unregulated. So the more voltage = more power.. 8V-16VDC.
  • RMS Power @ 14.4V
    • 1800W x 1 @ 4 Ohm
    • 3600W x 1 @ 2 Ohm
  • RMS Power @ 17.0V
    • 2000W @ 4 Ohm
    • 4000W @ 2 Ohm
    More input voltage means the amplifier will have to work less hard to make power.
    Don't expect the amplifier to work for very long however. the current drain on a class D amplifier is huge. There are no on-board fuses protecting the power supplies, so be sure to have at lease a 150A power line fuse.
    With 150A current draw - even with the amplifier at 1/2 gain - expect to get 10.6 minutes of listening time from your 16 volts before recharging - also note, the amplifier MUST see 8V to turn on, there is a built-in voltage sensor that will shut down the amplifier if voltage is too low.
  • Posted on Jan 23, 2009
    Anonymous
    • 73 Answers
    SOURCE: funcion for turning mario cart not working
    use the wii wheel
    Posted on Aug 25, 2009
    golfcartman
    • 34 Answers
    SOURCE: batteries run out of power too quick, what is my problem
    The voltage should be above 37 volts if you have 6 volt batteries. This must be measured under load. A simple voltage check is useless. If the batteries are over 6 years old, they are probably in need of replacement.
    Posted on Apr 21, 2010
    jim nicholas
    • 3 Answers
    SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
    never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
    Posted on May 15, 2012
    Is it possible to speed up an electric golf cart?
    Most electric golf carts run on a max speed of 12MPH. It all depends on the voltage. The higher the voltage, the faster the speed. Most electric carts out there run on either a 36 or 48 volt operating system and can only last about 20-25 miles per each charge.
    There are some new carts coming to market that are able to travel faster and possibly on less energy and can go up to 19 MPH. Many of the latest models are operated by computers and have quite a few high quality and unique components compared to older trolleys and carts. If you want or need something faster, they are worth look into.
    Aug 17, 2018 | Golf
    How to connect batteries on a parmaker golf cart series or parallel?
    suspect they are parallel to provide longer run life
    series will make shorter life but more power
    Jul 05, 2018 | Golf
    My golf cart has six, 6 volt batteries connected in a chain, positive to negative throughout. Can I connect an auxiliary light of some type to this power source?
    the cart is wired for 36 volts operation so you would need a 36 volt bulb
    or
    you could put the wiring for a 12 volt bub across the terminals of 2 batteries so the negative wire will be on a negative terminal of the first battery and a fused positive wire will be on the positive of the second battery
    the batteries are connected in series so the sum total of the voltage is the sum of all of the batteries
    by selecting 2 batteries in series you are using the sum voltage of 2 batteries
    Nov 24, 2017 | Golf
    Patterson elec golf cart . fully charged with new batteries After 8 holes power indicator flashes but cart still has power to complete 18 holes.Why does it flash
    Did you use the correct amp hour high quality batteries or just the cheapest, this is a battery voltage issue having to do with amp hour rating of the new batteries.
    Nov 30, 2016 | Golf
    Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
    Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
    You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
    Oct 20, 2016 | Golf
    I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
    Troubleshooting a golf cart - APLawrence.com
    aplawrence.com > Miscellaneous
    Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
    Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
    https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
    Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
    About Golf Cart Battery Chargers ' Golf Cart Talk Blog
    www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
    Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
    Basic EZGO Golf Cart Problems And How To Fix
    Feb 09, 2016 | Golf
    What amp out do i need from a charger to charge 3 x 12vot 14 amp hour batteries conected in series
    Connected in series the amperage is still 14 and the voltage is 36. Connected in parallel, the amperage is 42 and the voltage 12.
    Mar 10, 2015 | Motorcycles
    Golf cart electric charged but wont run
    not enough info to even guess and I won't..
    May 19, 2014 | Golf
    Trying to power a amp with 16 volts. possible?
  • RMS Power @ 14.4V
    • 1800W x 1 @ 4 Ohm
    • 3600W x 1 @ 2 Ohm
  • RMS Power @ 17.0V
    • 2000W @ 4 Ohm
    • 4000W @ 2 Ohm
  • Jan 23, 2009 | MA Audio HK4000D Car Audio Amplifier
    Golf Logo
    407 people viewed this question
    Top Golf Experts
    FastHarley
    FastHarley
    ray gallant
    Kardoc
    Are you a Golf Expert? Answer questions, earn points and help others
