Question about Bunn Coffee Makers & Espresso Machines
My Bunn Pour-omatic home model is leaking. How can I fix it?
Posted by Joey Kelson on
Kenita Langston
    New Friend:
I used silicone to make my own gasket, worked perfect
Posted on Jan 16, 2019
ray gallant
    Top Expert:
  • Bunn Master
  • 69,139 Answers
No fixing can be done sadly it is just replace it with a new unit
Posted on Jul 06, 2018
5 Related Answers
Steve
  • 3289 Answers
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Posted on Dec 02, 2008
Gord Thurston
  • 131 Answers
SOURCE: BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
Posted on Feb 11, 2009
mwarej123
  • 454 Answers
SOURCE: Should I leave the Bunn Pour Omatic Coffeemaker
Yes, the coffee maker keeps a tank of water pre-heated, that is what allows it to brew coffee in a couple of minutes. The exception would be vacation (away from home) or other times when you won't be using it for a few days. Visit www.bunnomatic.com if you have lost your user manual.
Posted on Dec 31, 2009
atbsmmom
  • 189 Answers
SOURCE: Bunn (Pour Omatic) coffee maker
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Posted on Jul 07, 2010
atbsmmom
  • 189 Answers
SOURCE: Have a bunn pour omatic
It is part of the rocker arm. If you will call customer service with the model and date code, we will be able to help you resolve this problem. The number is 800-352-2866.
Posted on Oct 20, 2010
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
My bunn pour- omatic only gives warm water --any suggestions?
TRY RUNNING WHITE VINEGAR THREW THE TANK, IT MIGHT BE ALL CALCIFIED AND THIS IMPEDES HEAT TRANSFER .. MIGHT NEED TO DO IT A FEW TIMES , DO IT TILL THE WATER IS CLEAR. JAY THE PUMP GUY FL
Feb 03, 2012 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Have a bunn pour omatic home model older one great cleaned and started to leak. what is this called a small plastic insurt in lid that goes into the hole where the water runs into, the top part in lid...
Oct 14, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Should I leave the Bunn Pour Omatic Coffeemaker plugged in at all times?
Dec 31, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
Jun 18, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My bunn coffee maker leaks, were can I get parts? it is the older white style
You can call Bunn Home division in Springfield, IL at (800) 352-2866. They have a kits which you can try at no charge. If that does not work, they will replace your coffee maker at discounted price provide you send the old one in. On the bottom of your coffee maker there is a modle number which they need on a white tag. .Hope this helps
May 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
Oct 28, 2008 | Bunn NHB Coffee Maker
BUNN Pour-Omatic
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee Makers & Espresso Machines Logo
299 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
