Question about Andis Health & Beauty
So I have andis agc super 2 speed brand new. I have literally shaved half my dog clippers now seem too dull or cant cut hair. IThis cannot be normal to hVe this much trouble with brand new clipper
Posted by Marcella buter on
Mark Cheong
    Master:
  • Andis Master
  • 791 Answers
First, I'm not a Andis Tech.
* Check your warranty and call for service.
*** Following is for information only ***
* Normally I would suggest cleaning and tightening the 2 blade holder screws as in a normal "Human" hair clipper. But I noticed this pet clipper uses a snap on blade (or a combo blade as shone in "Blade Maint" video. Looks like it's mostly cleaning though I have seen other vids with clippers going dull during pet "rescues" having to trim matted hair. One lady used 2 blades and ending up using a 3d blade. It could be just that; really thick dirty hair. Dirt and grime is a collection of stone dust and oils after all.
* Demo; https://www.youtube.com/watch?v=Aun5QDCtGgc
* Blade Maint; https://www.youtube.com/watch?v=v-rS_YQ-ro0
* Basic Repair; https://www.youtube.com/watch?v=CRGEQHhfCIc
* Repair (detailed); https://www.youtube.com/watch?v=pbDLhMugSgg
Aloha, ukeboy57
Posted on Jul 06, 2018
5 Related Answers
heidi muehlenberg
  • 62 Answers
SOURCE: I cant get my new
Could you please be more specific in what the clippers are or are not actually doing? Are they stopping when you attempt to clip the dog? Is the blade just gliding through the fur? What setting do you have the clippers on? Has the dog been bathed and combed? With a little more information I will be better able to help you.
Thank you,
Posted on Aug 19, 2008
Anonymous
  • 3 Answers
SOURCE: Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Posted on May 25, 2009
SOURCE: I have a Andis AGC 2 speed clipper and it keeps shorting out
No need to replace the clipper they are usually well worth repairing.
This sounds like a problem with you power cable they are just under £10, try moving the cable in different directions around the rubber strain relief coming out of the clipper.
Posted on Sep 11, 2009
SOURCE: I have andis AGC 2 dog clippers. I have having
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Posted on Mar 18, 2010
Testimonial: "Thanks so much for your help. The hinge assembly is what tripped me up. Once you explained that is was really quite easy. Thank you!"
SOURCE: Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
Posted on Jun 20, 2010
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
How do I find what model my Andis pet clipper is
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
Feb 04, 2014 | Andis AGC2 Hair Trimmer
Single speed
Maintenance must be done and clean the engine
Jan 25, 2014 | Andis Agc Super 2-speed Clipper...
Moser max 45 won't cut
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Sep 15, 2013 | Andis Agc Super 2-speed Clipper...
I have a Andis AGC super 2, I have only owned this since last summer so this unit has only been used 9 times. I cut three dogs and I have been through 6 drivers. WHATS the DEAL!!! I am going crazy. When I...
ok firstly you must oil the blade every 15 min's or so this wil prevent rust build up and also prolong the life of the blade. (further details can be found at http://angliaclipperservices.com/clipper_blades.html)
ensure the blade is snapped into place correctly this can be done by pushing the front edge of the blade away from the clipper. The blade should not detatch without the black latch being depressed so if he blade comes away simply push it into the clipper with it running until it is in place.
Apr 26, 2011 | Andis AGC2 Hair Trimmer
Andis super Agr+ / Andis Agc super maintenance
There is little needed most componets such as the motor and carbon brushes are fairly complicated and should be checked when the units are serviced.
Keep an eye on the Blade Drive Assembly as with most clippers they wear on the sides causing cutting problems such as lines in cut fur and snagging blades, alternatively send them, to our Clipper Repair department.
Mar 01, 2010 | Andis AGC Super 22360 Hair Trimmer
My 78950-100 will not cut my dogs hair
The clipper that you purchase dose not have the power to cut the Dog fur, You need a Andis Xcel 2 speed with a # 10 clipper blade. www.mannyssharpening.com this clipper is quiet and has power. [email protected]
Feb 04, 2010 | Oster 78950-100
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
Health & Beauty Logo
1,051 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
